Home > Help Needed / General Tech Chat > Easiest way to remove core and gallery plugs
madonminis
Member #: 9371
East Yorkshire
As above, need to replace my plugs, any hints as to the easiest way to go about removing them?
Matt
I normally punch a hole in the centre with a chisel and lever them out.
I just tip mine with a punch.
Water - drift one side until it rotates. Remove with pliers.
Oil - find suitable size tap. Keep turning tap until plug rotates. Then pull and turn until plug pulls out.
Edited by theoneeyedlizard on 1st Apr, 2014.
graemec
Member #: 1424
Carnforth, Lancs
Oil - self tapper then claw hammer.
But then, I've been called a rough bastard on more than one occasion!
Hammer and screwdriver for the water plugs, as above hit one side and rotate
madonminis
Member #: 9371
East Yorkshire
This worked perfectly. Good job I had my tap set with me.
