Home > General Chat > exhaust turbine
coopdog
Member #: 9628
im havubg trouble rotating the housing :/
tried giving it a good hit but it wont budge.
best thing to do?
It won't just rotate with the bolt slackened. You need to remove the housing and put it back on at your new angle.
If you are in fact trying to remove it, hit it harder (with a soft hammer).
lee.pb
Member #: 9199
Lancashire
I ended up warming the housing up with a blow lap and kept tapping it until it came out.
Be careful you dont damage the blades though kocking it out.
Yeh, get the gas burner out and heat the exhaust housing. Throw a lot of heat at it quick and it will come free quite easily. Try not let the core housing heat up, the reason for heating it quick.
