Home > Help Needed / General Tech Chat > first motion shaft lock tab
madonminis
Member #: 9371
East Yorkshire
I have installed a new locktab on the first motion shaft.
The gearbox is all back together (just about) and torqued up. But for the love of god I can't bend the locktab over first motion shaft retaining nut. The trouble is that it's so tight against the drop gear I can't get anything behind it to lever it into a suitable position.
Just posted in case someone had a handy little hint for how to do this.
Cheers guys
Matt
adcyork
Member #: 6807
York
Sharp chisel between the two and give it a tap just to pull it away then get a set of mole grips on it to fold it over
madonminis
Member #: 9371
East Yorkshire
Can't get my chisel in because of the curve on the gear and locktab.
The OEM ones are a pain minispares do a thinner one now as standard and its easy just bending it over with a screw driver, and their not expensive under 3 ponds
Lock tabs suck!
turbomoke
Member #: 10774
seaford australia
Gday mate, piss the lock tab off and use loctite. tab washers are made of soft tin and will compress over time. leaving the gear and bearing loose on the 1st motion shaft. We have not use one in 25 years.(race or road) Cheers Ben. Old Car Gearboxes Australia.*smiley*
