| Home > Help Needed / General Tech Chat > If its not the head gasket, then what is it? | |||||||
![]() 209 Posts Member #: 6451 Senior Member South East Northumberland |
12th Apr, 2014 at 01:28:42pm
I'm hoping someone on here can advise me on a problem I've got with my MPi mini.
12th Apr, 2014 at 01:36:37pm
On 12th Apr, 2014 Cooper1999 said:
So - am I correct in thinking if the head gasket had gone again it would show as two low cylinder compression readings? Not if the (single) cylinder with low compression had blown the gasket into an adjacent waterway rather than into the cylinder next to it (which would give you two low readings, but into a waterway would only give one low reading). Beyond that, without photos of the previous gasket, head, block etc. it's only guesses. Schrödinger's cat - so which one am I ??? |
12th Apr, 2014 at 01:54:42pm
Rod, this was the failed HG:
12th Apr, 2014 at 01:57:13pm
Did the valves in cylinder one look OK? Poor valve seal or the tappets being incorrectly set might cause these symptoms.
12th Apr, 2014 at 02:08:17pm
OK, the photo cleary shows the initial failure to be between 1 & 2.
12th Apr, 2014 at 02:29:35pm
Okay - I'll reset the tappets and see how that goes when I'm looking at it tomorrow.
13th Apr, 2014 at 08:44:19pm
Well, I checked the valve clearances - they were tight (around 0.2mm), so I reset them to 0.3. I made sure everything was connected/tight.... and no difference.
13th Apr, 2014 at 09:01:13pm
14 bar compression on an MPi?!.......... A little on the hight side? No?
13th Apr, 2014 at 09:58:25pm
I agree with Sprocket, that's not a standard MPI head, it's got a 36mm inlet fitted. It will be worth measuring the chamber volume to see if a lot's been skimmed off it.
13th Apr, 2014 at 10:16:26pm
EVERY time a Mini head is off, it needs tone vacuum tested. At least remove the valves to see if the valve seats are fine on both the valve itself and the head. On 13th Jul, 2012 Ben H said:
14th Apr, 2014 at 06:14:59am
Personally I like to try to find the reason for a head gasket failure before reassembly to make sure it doesnt happen again, is your ignition timing correct? I seriously doubt it! |
16th Apr, 2014 at 08:13:42pm
Blooming heck - there's some knowledge on here!
Edited by Cooper1999 on 16th Apr, 2014. |
16th Apr, 2014 at 08:16:25pm
16th Apr, 2014 at 09:03:37pm
cracked ringlands, caused by the engine not being tuned for its increased compression and airflow. this also caused the gasket failure? what im getting at here, is perhaps you have two problems :( turbo 16v k-series 11.9@118.9 :)
16th Apr, 2014 at 11:53:15pm
I've seen a bogo standard MPi destroy a piston, see if I can find the pic. On 26th Oct, 2004 TurboDave16v said:
19th Apr, 2014 at 10:42:19am
Just checked my records - the head was fitted at 55k. The cars past 93k miles now, so nearer 40 thousand miles, not 30.
Edited by Cooper1999 on 19th Apr, 2014. |
19th Apr, 2014 at 12:16:13pm
How do you know you have a goodun if you havnt pulled the pistons? Id have done a leak down before pulling the head to see where the compression in that cylinder is going:/ if the valves were seating ok, block and head were flat and no cracks can be found im afraid your going to have to pop a piston or two. turbo 16v k-series 11.9@118.9 :)
19th Apr, 2014 at 12:22:32pm
I'd want to say the head has a hairline cracking in one of the inlet ports causing it to burn a small amount off coolent.
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
19th Apr, 2014 at 08:38:01pm
Piston no 3 looks like it may have some damage to the crown. It may well be the pics/reflections.
In the 13's at last!.. Just |
19th Apr, 2014 at 09:22:18pm
Mayo in the breathers is not uncommon. I'd be more concerned if there was Mayo in the rocker cover. Has the cooling system been over pressurising? does your expansion tank look stressed at all? those are indicators of combustion gasses entering the cooling system.
20th Apr, 2014 at 02:30:15pm
Thanks for all the comments guys - I appreciate your thoughts.
Edited by Cooper1999 on 20th Apr, 2014. |
21st Apr, 2014 at 07:12:11pm
Well, started the day with this:
27th Apr, 2014 at 04:41:46pm
Not the best of pics but:
27th Apr, 2014 at 05:12:12pm
27th Apr, 2014 at 05:52:55pm
:( least u know! turbo 16v k-series 11.9@118.9 :)
). At the very least I'll check the vales and seats/lap the valves in again.
