Home > Help Needed / General Tech Chat > 3.7:1 diff with turbo
rattydriver
Member #: 10808
leicester
What's the general opinion of running a 3.7:1 diff with a turbo set up.... and valid reasons for and against
lee.pb
Member #: 9199
Lancashire
You really want a taller diff 2.9:1 or 3.1:1
This is all dependant on personal prefferance, you probably find you will run out of each gear too quick with the 3.7, thats if you can stop it spinning the wheels.
There's no way anyone can advise you unless you tell us what you intend on doing with the car.
A 3.7:1 would be great if you're hill climbing/sprinting, but not so great if you want to travel any sort of distance.
nky_84
Member #: 9213
Scotland
i'm going to attempt to run a 4.5:1 diff in my turbo... Albeit not a road car, but i'll report back how usable / unusable its going to be once its up and running properly!
eden7842
Member #: 8852
leicestershire
I agree with Gary, it's personal and depending on what the car is going to be used for.
I'm going to be running a 3.4 but I have been running a 2.9 for the last 3 years
I've been thinking about this over the past day or so re the diff I'm going to put into the metro. I've currently got a 3.6 to go in however, having watched the sprinting at Kames yesterday, I'm considering the 3.7 as well.
having said all that, my road car has a 2.9 in it
Edited by Rob Gavin on 14th Apr, 2014.
nky_84
Member #: 9213
Scotland
Depends on what the car will be used for, with the 4.5 diff, i was only just getting into 4th gear on the Kames main straight when in N/A spec (130bhp), so could of actually gone even more extreme to get the most out of the car. However there comes a point when you need to balance acceleration and having to constantly take a hand off the wheel to change gear! If your keeping to sprint tracks, then the higher the better, but if its road legal or your going to take it somewhere like Knockhill, then it will be terrible!
rattydriver
Member #: 10808
leicester
Not bothered about top speed , off the line and back road driving ....acceleration ....
lee.pb
Member #: 9199
Lancashire
I've gone for a 3.2:1 in the turbo on 10's.
The mini will be used for spirted driving and of course MITP and trackdays.
Had a 3.44:1 in the n/a and found it a little to high for motorways.
nky_84
Member #: 9213
Scotland
also depends on size of tyres and wheels. 13inch slicks add a fair bit to the rolling radius. low profile 10inch tyres are going to shorten gearing considerably.
1293 sprite
Member #: 5449
Melton Mowbray
You don't have to rev the nuts off turbos to get the power, so I'd go with a 3.1, or a 3.44 if you really want. Acceleration will be quick enough without going with a 3.7 imo
1293 88.8hp 82.2ftlb
17.3 1/4 @ 78 mph
Naturally Aspirated (for now)
now this is helpful as all my thoughts were on yesterdays viewing!
Car is the metro challenge car running a conservative 150-160bhp on 12's with 175 tyres (although I could consider 13's as well. The car originally ran a regulation 3.9 diff for track stuff. Unfortunately I've never driven it yet or driven a sprint of hill climb before so all my thoughts are just that
sorry for the thread hijack!
Rob
What is the bottom end spec of the engine, turbo choice etc? If the power band would suit the gearing then go for it.
this calculator may help you decide.
http://www.guess-works.com/Tech/ratio.htm
I'm using a 3.44:1 which is great for my car which is only used for the strip and short journeys ( other than driving to the strip ). I'm considering other motorsport too.
If it was only to be used on the road, I'd go for a 2.9:1.
For sale.... 3.7:1 straight cut (properly straight cut) crownwheel and pinion for standard/ cross pin/ ATB diff ... £100 plus £7.50 post
gearkit makes a big difference too,
IMO a 3.7 with a std helical box would have a completly pointless first gear.
I would think it has more to do with first gear ratio rather than top speed. I know from experience that with 100lbft torque, first gear on a standard A+ gearset was pretty much a waste of space.
A taller first is definately order of the day with the 3.7:1 FD
eden7842
Member #: 8852
leicestershire
O.T Gary what's your top speed at what rpm do you get?
I think yours is a similar spec to me.
Not been flat out in top yet Eden. If it was in one piece, I'd give it a try now.
Should be around 100 at 6k rpm, which isn't too silly really.
Edited by minimole23 on 14th Apr, 2014.
eden7842
Member #: 8852
leicestershire
That's kool I'm expecting 8k out this engine *wink*
Sounds good*smiley*
Similar spec... ? 8k?
eden7842
Member #: 8852
leicestershire
Fair point Gary.. It was. We both got into the 13's anyway
