Home > Help Needed / General Tech Chat > Trigger wheel....
snowfruit
Member #: 557
Ireland
Is this the correct trigger wheel for a MegaSquirt EDIS setup?
It looks a bit to invisible to be any good.
snowfruit
Member #: 557
Ireland
oops :p
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...mMakeTrack=true
sorry forgot to hit the paste button :p
Yes that will work, you'll have to remove 1 tooth.
Holy crap - That's a lot of markup he's making there!
No guidance on what you're meant to do with it either... Mine and Jims are laser-cut and mount behind the pulley similar to this (I guess).
The H boys looked to have a good solution IMO
snowfruit
Member #: 557
Ireland
Not worth it in your opinion TurboDave? if not where did you get yours from?
I made it from a DXF myself, then got it on a lathe and made it to fit between the pulley and timing gear cover.
As I said - what Wil and Ben (the H men) have done looks the easiest for the money.
snowfruit
Member #: 557
Ireland
If i remember correctly wil/ben_h have a ford trigger ...?
Yep, ford pulley trigger ring fitted onto a turned down mini pulley.
Total cost: lesst than £3.
i have a spare 36-1 trigger wheel here same as i use on my car
i saw that on ebay, but i reckon its too much, im goin down the ford route, while i save up for the KAD kit.
Ben H
Member #: 184
Melton Mowbray, Pie Country
The ford wheel fitted to a turned down mini pully looks like this:
Edited by Ben H on 2nd Aug, 2005.
http://www.twin-turbo.co.uk
the spare i have is a ford one
snowfruit
Member #: 557
Ireland
How much for your spare Wolfie? (inc postage to Eire)
