Home > General Chat > Moke Twin Cam k1200
Moke2b
Member #: 10814
Noosa AUS
Hi guys, I have been an avid reader for a long time grabbing pointers and learning as I read. I have been also learning and getting help from Matt Read over here in Aus. So this is taking me friggin ages to get to this point and I will take a couple of years more to finish. Engines going into an 80 Moke, fuel injected and turbo'd. A few foto's of the stuff I have collected for the build.
Worlds slowest Moke
Moke2b
Member #: 10814
Noosa AUS
So if these work I have some questions regarding gearbox setup that I will get too.
Worlds slowest Moke
turbomoke
Member #: 10774
seaford australia
Nice work. What state are you in ? I, m in vic and turboing my 72 moke. Only 8 valves though!
nice crank...
On 16th Apr, 2014 gr4h4m said:
nice crank...
Indeed.
That alternator looks huge.
Welcome btw.
Carl S
Member #: 1761
Stalker
Interesting crank!
Thats the swift 5 bearing imitation crank isnt it?
Look at those pistons... have you had those machined or are they made like that/ if so what make.. they look very much like a set of machines
d omegas to me
Moke2b
Member #: 10814
Noosa AUS
Hey Turbo Moke, on the Sunshine Coast. Have you got a link to your thread? Wouldn't mind seeing what your up to.
Thanks, yeah the crank is nice eh, hopefully it will perform when called upon. We're at the stage of trying to get a centre main cap made, I haven't really got too far with it yet, trying to do a 4 bolt design but with splayed bolts on the outer instead of having the two outside bolts parallel to the originals. Just before anyone pings me it is a k1200 LT head with an 1100 rocker cover .
Thanks for the welcome. The alternator is a bit big but I have space for it and it's billet, so I have soft spot for it.
I was wondering too, I am also starting to look at the gearbox side of things. I have picked up a 5626 case and was thinking of a close ratio synchro straight cut gear set and one of Swiftunes LSD's. So what I was wondering is if (apart from going to the trouble Matty has) what steps would you guys suggest as far as strengthening the box to get the most out of it? I'm sure it will be the weak link...
Worlds slowest Moke
Moke2b
Member #: 10814
Noosa AUS
d omegas to me
Yeah Brett your right it is the DC5 set up. The pistons are a billet piston and one of Nick's design. They are nice and light and I had to wait two months to get them made. They're 40 thou over with a 15cc dish to get the compression ratio down. Hopefully they will go ok.
Worlds slowest Moke
supermotolee
Member #: 2153
kings langley
Very nice!
they are nice pistons indeed
Billus89
Member #: 8931
I will second Brett, Nice pistons!
VERY VERY nice , any pics of the moke its going in.
This is going to be nice if the parts are anything to go by.
Have you anymore info on the rest of the engine, Ecu , turbo etc
Sorry I carnt help really on the box , im sure some of the more technical ones will be able to answer shortly .
rick
What is the target power output and useage of the engine?
Looking at the bottom end I would assume it will be making a lot of power and driven hard.
I would say a nicely stress relieved 5626 case, minispares evolution gear set and a quaife ATB or even bit the bullet and fit the Swiftune dog kit.
Edit, I'd love a 16v moke.
Edited by minimole23 on 16th Apr, 2014.
philc
Member #: 1346
bromsgrove
hi bud welcome to the site, looking good on the build so far. well worth you starting keeping a log of what you have done in the show section on the forum. In respect of gearbox's I am no expert, but I have a SCCR set with atb diff, this should be well up for the job. A lot of the guys on here are running high power outputs with similar boxes, you should not have an issues. I can't on the lsd you have described, but there is s recent topic on the site re lsd's, maybe worth a read.
Nice. Thats not a Swifty flywheel is it?
Moke2b
Member #: 10814
Noosa AUS
Yes it is a Swiftune lightened flywheel and backing plate, I think it's made to the same spec as the works rally flywheel? In fact the only things that aren't from Swiftune so far are the MED balancer and Matt Read's kit. I trust people who race.
I will get a photo of the car, might start a thread in the garage section soon too. It's basically a wreck that I bought for $500. An Aussie gal body Moke all rusty with holes everywhere. I have started the repairs and am changing a lot of things on the way. The plan for the car is to be registered on the road and 95% of the use will be for road stuff. But I also want to do hill climbs in it. So that's why I'm thinking of staying a synchro box, but am interested in the relieving comment made, can someone please explain what's involved?
Thoughts for the gear set and diff were the the Swiftune 4sp close ratio synchro set made by Quaife? And either a tranx Mark 6 LSD or an ATB, probably the tranx diff at this stage, although I would like some thoughts on that.
Haven't got too far on the ecu or turbo yet, I want to go sequential injection and a good turbo, but haven't thought too much about that as I have no experience in either. I have a good mate over here that has a shop that all they handle is pretty much fabrication, injection and engine swaps they trade as A&M auto in Noosa. Their web site isn't fantastic but they have a good rep and I trust them, he grew up around Mini's and they know their stuff so I will lean on them once the power plant is done.
Thanks.
Edited by Moke2b on 18th Apr, 2014.
Worlds slowest Moke
MadMatt
Member #: 105
Brisbane ,Australia
Lookin Good Pauly, & glad you finally posted it up here *smiley*
This will be the bling of all bling-mokes i reckon *smiley*
www.miniman.com.au
ah, I see. Why did you not go for his Super lightweight flywheel?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
come on then what turbo ?
Moke2b
Member #: 10814
Noosa AUS
Hey Matt, hope all's going good for you at the moment, will catch up soon I spose.
Well I am by no means a competent engine designer or builder, so I try and listen to those with more experience but I do think though that the lighter pistons and rods with the albeit lighter flywheel will be enough. I have heard a few stories of ultra light flywheels stalling easily, having to rev it hard to take off. Swiftune suggested this would be a good match for what I want. But I will add that I have never driven a car with a super light flywheel so I can't speak from experience.
Come on then what turbo
*smiley*
When I know you'll know, but once again happy to listen for suggestions.
*smiley*
Worlds slowest Moke
Ill be watching this keenly. Looking forward to seeing the car
