Home > General Chat > spark plugs
coopdog
Member #: 9628
Turbo running about 12 psi with nodiz what plugs do I need?
T3Tone
Member #: 252
Sunny suffolk
Ngk bpr6es should be fine.
-MINI CLUBMAN 1380 TURBO-
lee.pb
Member #: 9199
Lancashire
Sorry for hte Hi-jack....
16 psi running MJ
Would BPR7ES be acceptable
16 psi running MJ
Yes.
lee.pb
Member #: 9199
Lancashire
Cheers Phil,
16 psi running MJ
Yes.
yes but i had plug wetting probs at idle so i dropped back down to 6es i found those lasted quite well up to 20psi and well over with water, i checked plugs after every run and never had a bad one ( apart from the time i wiped all 4 out with too much water lol )
lee.pb
Member #: 9199
Lancashire
so its really trial and error, always seemed to foul up 7's with the 45 weber.
May just go for 6's and see what happens.
steve1275
Member #: 951
Bromsgrove
I run 7s on the road@18psi and 8s with NOS on the strip. Do have fouling probs with these if I try to run them on the road.
'Where does the engine go?'
Craigie-B
Member #: 9468
Wootton Bassett
when I was running the turbo which uses megajolt - I used BPR7ES and it ran like shit, put BP6ES into it and it ran perfectly
tadge44
Member #: 2500
Buckinghamshire
7,s never given me any trouble up to 17psi and it idles and runs without any temperament.
(Probably a credit to Robert,s profiling of my needle)
I run 7's & have only ever had fouling once. This was in winter when the engine wouldn't even get up to temp & the fuelling was a bit on the rich side at part throttle.
Phil.
