Home > Help Needed / General Tech Chat > Will not start
Nick warwick
Member #: 8926
Sheffield
I got my engine started for the first time last weekend and ran it in fine.
I finally got the brakes sorted so tried to give it a run but it ran like a dog due to fueling. Adjusted it a tiny bit and it ran better at the time, now the bloody thing won't start up no matter what i do!
Even if it is running lean or rich i would have thought it would still start? i am running a 20degree map that John gave me.
Not sure what to do now?
Nick
eden7842
Member #: 8852
leicestershire
1st thing to do is confirm you still have spark
Nick warwick
Member #: 8926
Sheffield
still have a spark, just cleaned the plugs up while i checked
Nick warwick
Member #: 8926
Sheffield
sorted! somebody had the coil pack numbered up wrong.
lee.pb
Member #: 9199
Lancashire
Sounds like you got your A/B wires wrong when wiring the coil pack lol.
If you needs some maps i've got loads (some off John), got another off Benross that i'm thinking of running as a base map.
What boost are you thinking of running ? As i believe the 20 degree Map doesn't go over about 10 psi. (i may be wrong though)
