Home > Help Needed / General Tech Chat > Turbo carb
snowfruit
Member #: 557
Ireland
"You are bidding for an SU HIF44 carb and plenum chamber from an MG Metro Turbo, both are in very good condition, however the dump valve piston is missing in the plenum chamber but the carb is excellent"
How serious / hard to replace is the missing piston? is it worth buying?
Nope, you'll only block it off *smiley*
dont worry about it
The standard plenum has no dump valve.
I guess what the he means is the pressure release or over boost valve.
Most people block these up, so it shouldn't be a problem.
Wil
snowfruit
Member #: 557
Ireland
Lovely :) thanks fellas
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
does he mean the damper?
Alex
AlexF
Nope, it definately says in the plenum chamber, cant see him getting it mixed up with the dashpot, although stranger things have happened *happy*
i think its off this item:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...4566123503&rd=1
i think hes referring to the 'thing' that keeps the dashpot piston damper from popping out during boost.
