Home > Wanted > Mk1/2 wheel boxes and tube
Hi all I have a mate that is after mk1/2 wheel boxes and the tube that joins them together.
Or alternatively a complete setup so that he can swap them over.
Thanks
Graham
Are they a normal rack but narrower? I might have one kicking around I'm not sure, I'll have a dig in the garage tomorrow
I think they have less teeth mate than the mk3 onwards.
I guess if we got the complete mk3 onwards kit we could just swap it all over?
Probably bud, I'll get a few photos for you and compare it to a later rack and see what your mate thinks
Thanks mate sounds great.
The wipers are closer together on mk1 so the middle tube is shorter - a later one can be shortened and re flared. The wheelboxes are different - the cog is a different size
Thanks Paul
The scuttle nut on the early one is 6 sided and 1/2UNF. The later one is 8 sided and metric, around 14mm.
If you've got an email I'll send you over the photos, can't upload them using my phone
Got these posted off to your mate today Graham.
Great thanks
