Home > General Chat > what needle?
coopdog
Member #: 9628
im almost at the point of starting my turbo build for the first time what is the best needle to start with?
1046cc
T2
120BHP
thanks
Edited by coopdog on 1st May, 2014.
what carb HIF44? try a BDD
essentially any NA needle is a good base needle, the fatter the better ( gives good scope for profiling)
i think i went through about 10 needles before settling on 2 hybrids,
both had comparable 0-3 sections ( same profile as a BDD) mid range was very different due to the way the GT20 spooled ( all or nothing *tongue* )
my low boost needle had the 6-12 stations similar to the BDL ( i think) just abit thinner and was ok upto around 15-18psi
my high boost needle 0-3( same as BDD) 6-12 very thin
both my needles were settup with the jet a couple mm down from the bridge making them very very rich and i used a redesigned lean off pipe with adjustable bleed valve to pull it back by between 4and 6afr at idle and low throttle position
tadge44
Member #: 2500
Buckinghamshire
Sounds very cunning - and effective too !
