Home > Help Needed / General Tech Chat > gearbox casing number
sam_shelton
Member #: 251
Nottingham UK
What is the standard metro turbo casting number supposed to be. I searched this forum and google but can't find any information.
Sam
Id guess the same as any other 1275 a+ gearbox *smiley* they all use the same casing with just varying final drives.
The one to use is the DAM58## or maybe DAM##58 - I forget!
This had the strengthed idler support - but I don't know of any other major differences between this and the 998 A+ tranny casing.
sam_shelton
Member #: 251
Nottingham UK
Thanks for that I have three of the DAM 58 casings two of which are definite turbo boxes but not sure about the third but I was hoping that was the standard number for a turbo box.
Oh well spose I will have to look at the diff ratio to get more of an idea.
Dangerous
Member #: 417
Dam 5626 on two turbo boxes round here
5626 was the number I was thinking of... Cheers Brian.
sam_shelton
Member #: 251
Nottingham UK
Sorry my mistake I have 5626 on mine not 58. I am really hoping that this engine/gearbox is turbo as it was cheap but on closer inspection it seems that the head is not turbo or at least the valves aren't. Oh well can't win them all!
Dangerous
Member #: 417
check the distributer number then
Nick
Member #: 154
Midlands
have you got the engine number dude?
pre 89 leaded engine is : 12HD26
unleaded is : 12HF01
I've got a 998 A+ box (with 3.1 diff) with the 5626 number here - these were generally just for the 1275 A+
Does it really matter if it's turbo or not?? NOPE!
