Home > Technical Chat > can i get away with this
Rammie2000
Member #: 10190
belgium
If i put on a heat sheald on can i get away with this or should i remove the servo and relocate the turbo?
Would like to keep it because its left hand drive and its quit some work to get it out ( bar acros to operate the servo)
Rammie2000
Member #: 10190
belgium
As for brakes it will either be 7,5 with 4 pots or 8,4 mini disq ( drilled) with metro brakes.
Couple of good heatshields and some wrap around the manifolds and you'd be fine I'd say. Or see if you can reroute the pipes a little further away from everything.
Rammie2000
Member #: 10190
belgium
The exhaust pipes ? Maybe i can make them bit longer so the turbo sits more in the wing
is stainless steel a good heatshield? .
Edited by Rammie2000 on 14th May, 2014.
Yeah, just try and move the turbo away from the master cylinder a little bit more, and stainless is pretty good as a heatshield. I Think it was wintersurfer who used an old stainless saucepan as a heatshield for his turbo to good effect.
Rammie2000
Member #: 10190
belgium
ha could it be him i saw on you tube then?
here is another one
http://www.supraforums.com/forum/showthrea...te-up-with-pics.
glad with the point that i can keep the servo though.
i looked at it an can move it away for another 4 cm easy.
i seen gold heat shield foils to... its stuf that works or just some bulsh....t ?
