Home > Help Needed / General Tech Chat > Gearbox shafts? Dead or good? Pic Heavy
Chalkie
Member #: 9764
Northamptonshire.
Evening Lads
Few pictures of my Gear box shafts can you let me know if they are keeper or not thanks
Lay shaft
Reverse Shaft
Main Shaft
Thanks
Mainshaft looks ok,
layshaft, the important bit is the bearing surface, maybe clean it up with a bit of fine emery as hard to tell with the crud.
Edit, as long as there's not pitting or corrosion on all bearings surfaces you should be fine if they clean up.
Edited by minimole23 on 26th May, 2014.
Chalkie
Member #: 9764
Northamptonshire.
Lay shaft its shelf has a small lip on pics 1 4 and 5 looks like a bearing has got hot on it at somepoint
its a 60,000 mile box as well
Layshaft needs replacing, reverse shaft may be ok. Mainshaft looks ok on the centre bearings, but couldn't really see what the 1st motion needle roller face looks like on the end...looks a bit blackened?
Chalkie
Member #: 9764
Northamptonshire.
Think its dirty on the main shaft, Oil in the box was like treacle
I'll dig the mint reverse shaft i binned earlier incase yours doesnt clean up.
Chalkie
Member #: 9764
Northamptonshire.
Nice one dude Ill clean it tomorrow
GT85 and wire wool do the job?
Your better off with thinners/brake cleaner and scotchbrite.
Chalkie
Member #: 9764
Northamptonshire.
Been told Main shaft Roller bearing faces are pitted meaning thats a gonner to?
Pitted= gonner
You haven't taken a picture of the most important bit on the main shaft. The little end inside the 1st motion shaft. Looks rough. Looks scrap.
Chalkie
Member #: 9764
Northamptonshire.
Want me to go get a picture?
Chalkie
Member #: 9764
Northamptonshire.
Few more pictures
jonny f
Member #: 9894
Dorking
I got a used good mainshaft of guessworks. If that helps.
Chalkie
Member #: 9764
Northamptonshire.
Just had a look on his site he's got a few in stock so gonna order one Friday
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
on the topic sort of..
to check for surface hardness where is the best place? clearly not where a bearing runs. .
middle? end?
asking as ill be using new main and lay and dont want the hassle of a shit one
already had problems with it not being ground to size it had a taper on the bearing surfaces !!
Not sure if it's only discolouring, but if it's pitted, even the slightest bit, it's scrap.
Chalkie
Member #: 9764
Northamptonshire.
Main shaft is a deaden so is the 1st motion gear and bearing :/ seriously
300 quid mini turning into a... watch this space haha
