Home > Show Us Yours! > My intercooler set up.
TurboMike1992
Member #: 9928
Hartley, Kent
Probably be handy for someone as im always looking for intercooler pics, heres my set up.
Phase 2 escort rs turbo cooler iirc
Not the greatest looking thing in the world, but seems to work well and do its job, also is fairly stealth install, dont really notice it at first glance :)
Low boosting for now.
Could it be moved back if running without a dizzy?
as long as it keeps the temps down thats good ........ iam a fan of bigger intercoolers though
TurboMike1992
Member #: 9928
Hartley, Kent
yeah definately could be moved back without a dizzy but it does the job! megajolt is being installed this weekend :) so hopefully will be on the hunt for a nice intercooler + a nic plenum, however i like the fact you dont really notice it at first glance
The RST intercoolers are very good for their compact size. Good installation.
I'm using the Pace double size phase2 RS intercooler. Perfect size to fit in the inner wing. Hopefully the extra size should offset its location
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
If you can duct it a bit id say bigger out of main flow is better than small in main flow
After all heat transfer is more about giving it time to do so as you cant make the ambient air colder!
In terms of ducting dont always just think air feeding it it can be done inways to make negitve pressure behind it to pull air
That aproch dumps the heat away where in cant recirculate as well
