Home > General Chat > what carb do i have?
welshdan
Member #: 1111
s wales
im having a clearout of parts not required and came across this. looks to be an HS carb of some sort.
is anyone able to id this for me please? thanks, dan
Chalkie
Member #: 9764
Northamptonshire.
Wax stat Hs4 carb nothing special
hs4maybe
what diameter?
welshdan
Member #: 1111
s wales
will measure tomorrow. am I measuring the dashpot diameter?
cheers, dan
welshdan
Member #: 1111
s wales
ps if its a hs4 whats the hif equivalent?
hif38? cheers, dan
second picture the shaft that the throttle plate slots through diameter of that hole, im gonna guess 1 1/4 inch from a 998
HIF38 has a 38mm choke
HIF44 ...44mm simples :)
1.5 inch would be the 38, 1 3/4 would be the 44
there isnt a hif as small as the hs4 ( as far as i know ) at least not on minis *happy*
Edited by Brett on 30th May, 2014.
welshdan
Member #: 1111
s wales
cheers for that!,dan
Alex
Member #: 1851
Woolavington, Zummerzet
It's an HS4 1½" = HIF38.
The HIF38 is technically smaller than an HS4 - 1½" is 38.1mm.
I suspect, however, that the HIF38 is just a renamed HIF4 (which I can't be bothered to go and dig out of the loft to measure).
The 1¼" HS2 has vertical mounting bolts not diagonal ones.
