Home > Technical Chat > T2 exhaust manifold
Choppo
Member #: 409
As some of you may have read in general chat, thinking about a 998 turbo, but I what to try and avoid cutting the bulkhead.
Iain suggested that with the mirage manifold and a T2 clearance is ok. I was wondering if anybody has done this.
Also whats the clearance like with a standard exhaust manifold and the adaptor plate for a T2?
Cheers chaps,
Choppo. *smiley*
Hannibal: There are two ways we can do this: the easy way and the hard way. In a few minutes my friends and I are going to come down on you like your worst nightmare. You're gonna wish the Earth had opened up and swallowed you whole.
bad guy: What's the easy way?
Hannibal: That WAS the easy way.
Basically if you use the Mirage kit you do NOT need to cut the bulkhead, if you use the Metro manifold, with a T3 or a T2 you WILL need to cut the bulkhead.
The choice is yours ........
Phil. *smiley*
Simply and to the point Phil *happy*
End of the day thats the size of it *smiley*
Choppo
Member #: 409
Nice, thanks chaps!
Chops.
BA_Lordflash
Member #: 26
Cannock
The only other thing you may have to think about with the Mirage kit is the down pipe might need a trim due to the fact that it ment to fit a 1275 which requires a slighty longer down pipe than a 998. This may or may not be an issue as i have never tried it.
