Home > Help Needed / General Tech Chat > oil seal behind clutch
easy to replace, mines gone thats what killed my clutch at avon, i have a spare one in the garage but have never changed it in situ
Not too bad at all, a trick if you can't get it out, is to remove the c-clip that retains the primary gear, and then pull on the primary gear itself to pull the seal out.
Other than that there is the usual method of drill a small hole in the seal, then screw a self tapper into it so you can use a pair of pliers to grip the screw and pull it out.
I am sure you won't struggle much to do it, the tricky bit is making sure you don't damage the lip on the new seal when pushing it into the housing!
i have an original austin tool for re installing
cheers for the reply when my finger goes down a bit ill go whip it out ... the seal i mean
Edited by wolfie on 5th Aug, 2005.
Careful about whipping it out, you'll get gaydar all excited!!
just did it
took less than 2 mins with my 30 year old austin tools lol
