| Home > Beginners Tech > Rounding off brake line bolts! Help needed! | |||||||
4 Posts Member #: 10883 Junior Member |
21st Jun, 2014 at 10:46:41am
Hi all,
Edited by metroturb on 21st Jun, 2014. |
21st Jun, 2014 at 10:50:32am
Get a proper brake pipe spanner, but be prepared to cut the pipe to undo the union nut with a 6point socket, obviously then you will need to make new brake pipes.
21st Jun, 2014 at 11:39:35am
As tom says, sometimes cut the pipe and a 6 point socket, I've had good results removing rounded off unions with a pipe wrench On 26th Jan, 2012 Tom Fenton said:
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
21st Jun, 2014 at 02:41:33pm
I have one of these. it is relatively wide (wider than the nut) and super stiff (it will NOT open up like some cheaper versions and kill the nut) and tight fitting hexhead.
Edited by Sir Yun on 21st Jun, 2014. That sir, is not rust, it is the progressive mass reduction system
21st Jun, 2014 at 04:27:39pm
As it's already fucked, I'd cut the pipe and use a Irwin bolt extractor socket thingy.
In the 13's at last!.. Just |
21st Jun, 2014 at 05:07:29pm
No reason you cant get that with mole grips. You need a decent pair tho and dont be shy on locking them on. You will still need to replace the nut but if you can get it out first you only need to cut off the flare and can maybe reuse the pipe. I you cut it off as is you will loose 20mm of pipe and that may make it to short to use again.. Just my take on it..
21st Jun, 2014 at 08:48:58pm
vise grips or pipe grips with work if all else fails (good quality ones though) |
301 Posts Member #: 10610 Senior Member Wiltshire |
21st Jun, 2014 at 10:12:30pm
I had the same problem used mole grips in the end totally rounded of so got a new pipe |
22nd Jun, 2014 at 07:12:03am
Just get hold of a correct spanner. It will hold the nut correctly and generally avoid this. |
22nd Jun, 2014 at 10:14:36am
Yip, good quality tools make a huge difference here..
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
23rd Jun, 2014 at 11:17:08am
Undo the other end and slide a normal ring spanner up the pipe. Metric is for people who can't do fractions. |
