Home > Help Needed / General Tech Chat > more clutch helps please
sorry fot the quastions its been a very long time since ive done a pre verto clutch
ive put the wok on but the arm is now right tight up to wok with a slight bit of pre load
is this right? i thought there was a little slack?
Dangerous
Member #: 417
The adjuster bolt halfway along the arm normally sticks out about 1/2"
Be over soonish
Should be 12 thou clearance between adjuster and arm with clutch arm held manually towards the inner wing (return spring removed)
the arm is resting on the screw tom
i have a good clutch and it bite halfway though the pedal travel so should be good enough for USC tomorrow
im going to build a new bottom end anyway
Dangerous
Member #: 417
Best take some tools and have a tinker in the pits,shorter bolt maybe so it dont catch the cover plate when its in
