Home > Show Us Yours! > New air box for TM member
steve w
Member #: 1917
AKA chargedzetec
I thought I'd put up a few pics on something I've been working on
I was given this drawing
So made this pattern from tooling block
Then a mould from tooling prepreg
Then made the part and vacced it down
Took 2 hours to get it out of the mould
199grams
Added the base plate, and cut a hole for the inlet (not shown)
375grams
Going to add the inlet tomorrow, and the outlet holes. And it'll be all done!
Looks ace =)
Impressive stuff.
Could you do something a bit smaller and capable of standing 2 bar pressure?
very nice
sim_ou_nao
Member #: 114
Porto/Portugal
This is for webber? good skills :)
Pedro Silva
very nice
steve w
Member #: 1917
AKA chargedzetec
In short, yes.
But.
I've already had one stress calculated, and it needs to be around 1.5mm thick, if I orientate the plies at 45 degrees, which uses more material.
It's something I've been thinking about, just not sure I want to
I did quite a bit of research and concluded that I needed a 2 piece mould and a bladder. An open box type mould and bonded flange would not do the job.
In the end I've reverted back to welded stainless.
Looking good
steve w
Member #: 1917
AKA chargedzetec
Yes, but a bolted and bonded flange would. It's nothing too difficult, pretty much the same as what I've made here.
Just a fair amount of work.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
That's brilliant, there's so much talent on this forum.
On 7th Nov, 2008 Nic said:
naeJ
m
Billus89
Member #: 8931
Great work. Nice to see some carbon work going on. Thanks for sharing
Very nice
Bugger, here we go again *frown*
Secshual!
steve w
Member #: 1917
AKA chargedzetec
very nice, would would you charge for something like this?
Aubrey_Boy
Member #: 9962
Looks nice,
Will you carry out a practical pressure / vacuum test of the completed & assembled part?
I have had quite large discrepancies between simulated and actual practical behaviour especially with joined assemblies subjected to N/A depression levels
sim_ou_nao
Member #: 114
Porto/Portugal
Amazing...
Pedro Silva
steve w
Member #: 1917
AKA chargedzetec
On 25th Jun, 2014 Aubrey_Boy said:
Looks nice,
Hadn't planned to, didn't see the need??
steve w
Member #: 1917
AKA chargedzetec
Feel free to share!
steve w
Member #: 1917
AKA chargedzetec
Not really, time is an issue. I fit stuff like this in when I think I have the time. Or if its fairly simple, I have someone who I sub the work out to.
If you have to make a 2 piece mould...how is that done ?
I presume the join area needs to be totally smooth ?
steve w
Member #: 1917
AKA chargedzetec
You have 2 options, lose the join on a sharp corner as I have done.
Or make the mould in 2 cures. Shutter the mould down the middle, and make each half in separate cures.
That way the join will meet up perfectly.
Chalkie
Member #: 9764
Northamptonshire.
Looks good dude!
