Home > For Sale > Injection, Head, SC Box
dischub
Member #: 8143
London
Up for sale is a brand new SC 5 port injection kit, up for sale due to unforeseen circumstances and having to sell up my project. This is the newer updated kit which has the one piece throttle shaft and no choke lever as it was found it wasn't really needed. The SC air filter and thermostat housing threaded for the water sensor is included.
This would set you back £1305 plus the shipping, up for sale at £1200
Straight Cut box, built less then 2000 miles ago
Built to perfection by me using the minispares Clubman gear kit
Brand new bearings all round heavy duty layshaft
the case centre web has been stress relieved and polished to a mirror finnish and drilled + tapped ready for a baffled sump plate ( needs a new one )
Xpin diff built with all new parts
the synchros are the best pick out of a hand full of boxes, it never crunched a gear even shifting over 7k and with all the boost i could throw at i
it came out as good as the day i built it, i can give it a quick going over for the buyer but the tolerances are literally still at the minimum ( i was very ocd about getting everything down to the min tolerance)
£600
Up for sale is a stage 3 head originally worked on by Morspeed. It was then reworded by Rob Walker engnineering. The following work was carried out
Has only done 10 hours use since rebuild, 11 stud fitment.
New race valves are produced in EN214N steel and are stellite tipped and use the later narrow, single collet groove and current valve head shapes. They are plasma heat treated to eradicate wear from unleaded petrol but has always been run with Millers lead additive. Also new maganese bronze valve guides fitted at same time. 35mm inlet and 29mm exhaust. New Kent race double valve springs and new top caps. New stainless steel manifold studs and thermostat housing studs. New heater tap blanking plate and temperature sender blank.
I had Stuart at Vmax look at it who told me it is ready for unleaded and the work has been done to a good standard for a stage 3.
£600
Edited by dischub on 17th Jul, 2014.
Sorry to hear your selling up mate good luck with sales, but pics dont work btw
Arnoud
Member #: 1085
Netherlands
What's the bearing and the gear doing at the bottom of the tranny casing?*wink*
1963 Cooper
1975 Pick Up
Arnoud
Member #: 1085
Netherlands
Good looking stuff otherwise:)
Edited by Arnoud on 28th Jun, 2014.
1963 Cooper
1975 Pick Up
dischub
Member #: 8143
London
Thanks Brett, Arnoud that's the input gear as the SC drops weren't included, best place to keep it as I'd end up losing it!
oliver122
Member #: 9625
what's the best on the box you will do mate delivered
dischub
Member #: 8143
London
£600 is a good price, delivery would be about £30-40.
dischub
Member #: 8143
London
I'm up for sensible offers guys, just no silly offers for example of £500 for a brand new injection system.....
Andy500
Member #: 2443
Cheshire
I would take the box if its still available and you could do it for £500 delivered?
Thanks
dischub
Member #: 8143
London
Sorry I can't do it for £500 delivered, I dont have something suitable to send it in and dont want to risk it getting thrown around.
I've been asked about the SC kit, SC confirmed the warranty does still run with the new owner and they will provide technical help if needed.
baker_boy
Member #: 9226
Rushden
I really really need that box. Can't believe its not been sold already. Why does no money have to occur now :( if I can sell my sud id have this straight off you.
i got nothing but time..
dischub
Member #: 8143
London
It will probably still be around Baker_boy!
I've dropped the price of the SC kit, I'll take reasonable offers guys, I'm already losing a lot of money so nothing silly. I'm not desperate to sell, they make good ornaments at the moment!
wayne miller
Member #: 10890
Twin Cam Turbo Build In Progress Rothwell, Northants
Ive just put a shit load of performance scooter parts off my sprint bike up for sale on another forum. They should sell pretty quick. I'll PM you about the box
05bwardl
Member #: 9991
lichfield ,staffordshire
Hi , would you consider spliting the diff or would you like it to all go as one ?
