| Home > Help Needed / General Tech Chat > 3 phase to 1 phase converter | |||||||
28th Jun, 2014 at 11:32:51pm
Can any one tell me how to wire this upto a 3 phase compressor??
29th Jun, 2014 at 06:56:47am
r and s will be single phase in, uvw will be your output but you need the datasheet for it to check with the dc tabs it could be a dc inverter... so putting a single phase on rs could make it pop lol turbo 16v k-series 11.9@118.9 :)
29th Jun, 2014 at 07:55:04am
Mike have you bought this as a specific 240 1ph to 415 3ph converter? Or is it just an inverter you've got from somewhere? As it may not do what you want?
29th Jun, 2014 at 08:03:11am
Part of the Rockwell group, go here http://literature.rockwellautomation.com/i...e_category.hcst and click on "Drives - Allen Bradley" and select the model.
Edited by Rod S on 29th Jun, 2014. Schrödinger's cat - so which one am I ??? |
29th Jun, 2014 at 08:06:27am
http://docs-europe.electrocomponents.com/w...66b8034c91a.pdf
29th Jun, 2014 at 05:21:47pm
My brain hurts!! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
29th Jun, 2014 at 06:00:38pm
It is a variable speed drive for a three phase motor. Looking at the literature, the only one good for 415v output needs a 415v three phase input, so it won't do what you need. |
30th Jun, 2014 at 08:05:54am
Itll be going on ebay then!
30th Jun, 2014 at 09:15:18am
On 29th Jun, 2014 Tom Fenton said:
Mike have you bought this as a specific 240 1ph to 415 3ph converter? Or is it just an inverter you've got from somewhere? As it may not do what you want? The reason I asked this is that sometimes they can be modified to do the 240-415 job. I have one that has been altered for that very purpose and it runs my three phase mill a treat. If you look at the standard documentation it appears to just be a standard 3ph inverter. I bought it specifically from a place called Drives Direct near Mansfield and it has worked without issues.
30th Jun, 2014 at 09:19:52am
How did you modify it Tom? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
30th Jun, 2014 at 09:36:10am
I didn't. I bought it from a place that sells specific inverters to convert 240 single phase to 415 three phase. It was about £350 from memory.
30th Jun, 2014 at 09:46:20am
Ahh right,
