Home > Help Needed / General Tech Chat > 16v conversion.. what flow rates are you using and line pressure?
JetBLICK
Member #: 1261
Droitwich
Looking at bits for fueling the 16v conversion. Im particularly interested in tuned examples, if you've upgraded the injectors, and stuff like that
Thanks, Dan
slater
Member #: 1291
Suffolk / Birmingham
Standard 180cc BMW injectors are good for 130ish bhp so that basically means they are ok for most NA conversions. If you are going turbo or higher end of NA tuning you will need to fit 220cc.
That's the way I understand it anyway!
nky_84
Member #: 9213
Scotland
i ran 150cc injectors and 3.5bar when NA @130bhp.
I now run 440cc injectors with the turbo, bit overkill i think, but will support crazy power / boost if required....
or a fuel that needs to run richer....
nky_84
Member #: 9213
Scotland
indeed.....
richer in what sense? *tongue*
and thats why the AFR unit of measure is shit
you know what i mean lol
if you run on e85 for example the injectors will need to flow about a third more or something like that,
if your stuffing a load of toluene in the petrol you might need 15% more flow.
Lambda unit of measure is the future. Lambda 0.85 on petrol is still lambda 0.85 on E85 but the afr is hugely different
yep, it is the best way to do it,
