| Home > Beginners Tech > 998 gearbox housing on a 1275 block | |||||||
211 Posts Member #: 10890 Senior Member Twin Cam Turbo Build In Progress Rothwell, Northants |
4th Jul, 2014 at 07:20:45am
Hi All,
4th Jul, 2014 at 08:47:47am
Yes. But, if mixing A and A+ engines/boxes you need to sort out the drop gears, but that's easy. On 13th Jul, 2012 Ben H said:
4th Jul, 2014 at 10:41:57am
Housings are all interchangeable. As far as I know the only 998-1275 transmission difference is the primary gear bearing size.. ? |
4th Jul, 2014 at 10:44:24am
Oh and the small bore transfer housing doesn't have the breather drilled normally but you can change that!
4th Jul, 2014 at 11:31:42am
Awesome, you guys are just what I need. Its like having an online pit crew :)
4th Jul, 2014 at 12:40:11pm
So if you pulled the complete gearbox and transfer casing off a 998 block it would fit but as others say you would just need to sort the drop gears out and the breather hole On 26th Jan, 2012 Tom Fenton said:
