| Home > Help Needed / General Tech Chat > Water cooled oil filter housing ? | |||||||
![]() 328 Posts Member #: 9107 Senior Member Devon |
4th Jul, 2014 at 08:16:59am
Trolling through the bay and found this
4th Jul, 2014 at 08:19:28am
Metro turbo didn't have them, the MG Metro did.
4th Jul, 2014 at 08:49:09am
On 4th Jul, 2014 John said:
Metro turbo didn't have them, the MG Metro did. When we tried one on the van we found it didn't do a lot to cool the oil but did plenty to warm up the water! lol I'd sign up for a physics course if I were you.... On 13th Jul, 2012 Ben H said:
4th Jul, 2014 at 08:55:17am
From a N/A MG Metro, I have one in the shed from my donor car.
4th Jul, 2014 at 08:59:08am
last i checked coolant should be something like 75-95c and oil 85-110c via
4th Jul, 2014 at 09:43:44am
Metro turbo didn't have them, the MG Metro did. When we tried one on the van we found it didn't do a lot to cool the oil but did plenty to warm up the water! lol I'd sign up for a physics course if I were you.... I'd rather not bother signing up to anything and just take my personal experience of using one into account. I know how a fluid to fluid heat exchanger works. My wording may not have been great but in summary it did cool the oil somewhat but not as much as I would have hoped, the benefit of marginally cooling the oil was more than offset by the increased temperature in the coolant system (to the point of overheat at some times). Improving the efficiency of the cooling system may have yielded better results from the doughnut oil cooler but if I were to do it again I'd install an oil to air cooler (as I will probably do in the mini). If something is worth doing, it's worth doing half of. |
4th Jul, 2014 at 01:20:56pm
Ok then On 13th Jul, 2012 Ben H said:
![]() 539 Posts Member #: 6807 Post Whore York |
4th Jul, 2014 at 04:02:54pm
These were fitted to the mg metro, primarily, to heat the oil up quicker from a cold start. This not only helped over the emissions cycle required for homologation but it also helped boost fuel economy figures over an urban drive cycle where the A series was considerably uncompetitive.
4th Jul, 2014 at 05:24:50pm
My word, it really is V's time of the month this week. On 11th Feb, 2015 robert said:
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
4th Jul, 2014 at 06:44:02pm
Im sure in a few hours he will
On 4th Jul, 2014 apbellamy said:
My word, it really is V's time of the month this week. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
4th Jul, 2014 at 08:36:33pm
an oil cooler is abetter bet imo
Yes i moved to the darkside |
4th Jul, 2014 at 09:55:48pm
Just to say, if you notch the upper flange of the subframe then the oil/water exchanger can be used in a mini with a full size oil filter, which will just sneak in whilst leaving the lower flange alone.
4th Jul, 2014 at 10:42:42pm
IMO and johns if you want to boil you water, which is on the limit in a hi powerd turbo mini then go for it ................... over the years i have thrown dozens in the skip
