Home > For Sale > Complete Bolt in, ready to go Nissan Conversion.
Tomm
Member #: 1432
Kent
Hello Chaps,
I have finally got everything removed, out of the way and this is up for sale.
This conversion has gone through 3 MOT's and has been completed and on the road since around 2011.
This is a full conversion, everything you require to install the engine into your car.
Complete engine, all ancillaries, and gearbox from a very low donor car, V5 and photos of the original car are available. This is the 1.0 engine but has been remaped, Before and after rolling road prints are available, I think it is around 80hp on the current remap.
Complete subframe, fits under a standard round nose. Will include lower arms, tie rods and Minisport hi-los and cones, all poly bushed. Please Note, this is twin bolt.
Complete pre-made loom, every thing is spliced together and ready to be installed in the car, I am including the whole loom for the car and the engine, it will come with relay and fuse boards, all fits behind the dash and works perfectly.
Driveshats
Pedal box, this has been modified to take the cable clutch
ECU, Ignition barrel, Key and NATS immobiliser system
Nissan Fuel tank, pumps, the lot
Cooling system Radiator, Metro rad or something of that kind, pipes are all there, it does work, it does not over heat, but it could do with tidying up.
Dials are included, not sure what they are out of, they are marked VAG on the back but look almost identical to standard Nissan clocks. I also have the original low mileage clocks.
Manifold, I will include the straight through link pipe and back box for extra.
I will most probably have missed something but everything you need to install this conversion is included in the advertised price.
Photos, these are the only real suitable ones I have to hand at the moment. I will get photos of the bare frame, engine, loom if wanted.
PRICE
I am after £500 as it is for a bolt in conversion, I am not interested in silly "Cash" offers. Of course a Gratuity donation will be made to TM for the privilege
Shipping is available, whole lot on a pallet any where in the UK mainland for £65.
I am based about 10 minutes from the IMM show ground, I am more than happy to meet people here if they plan to collect, or pop by and collect, either is fine.
Any questions are welcomed.
oli79
Member #: 8480
Driveshats lol
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Tomm
Member #: 1432
Kent
Haha I've posted this in a fair few places, you're the first person to notice haha!
That sounds like a decent deal. Guess the 1.3 would drop straight in too?? Just needs a turbo!
Tomm
Member #: 1432
Kent
Thanks John.
You are correct, the 1.3 drops straight in.
After a bit of reading there is a chap in Trinidad who has turbo'd one with great success, there is also a lot of information out there.
Buy a smashed up Figaro, straight swap.
Arnoud
Member #: 1085
Netherlands
as for the gauges: V.A.G. means Volkswagen Aktien Gesellschaft (ie not Nissan*wink*
1963 Cooper
1975 Pick Up
Tomm
Member #: 1432
Kent
Exactly (I am a huge audi fan when I'm not stuck under a mini) they look as though they may be MK4 golf but not 100% sure! either way they aren't Nissan.
Georgeb
Member #: 10810
Kent,medway
Hi tomm
Been trying to get hold of you. Have pm you
austin_minnie
Member #: 10495
Whats the gearing like? Are you max'd out when doing the motorway trek?
charlieb150
Member #: 9931
brighton
pm'd
