Home > Help Needed / General Tech Chat > What thickness sheet metal have you used for Miglia bulkheads?
Mowen123
Member #: 5593
Taunton, South West
As per title, I can't figure out what thickness to order for making my miglia bulkhead out of. 2mm seems like it would be really heavy, but not sure if anything thinner is substantial enough?
What have you guys used?
Mike
is that 0.2mm?
mine is made from 0.9, its about the same weight as what came out ( but much deeper)
mine in the making -
mini93
Member #: 2017
Warwick.
I've used 1.2mm Aluminium.
Reasoning behind it was I already have a weld in roll cage, mounted to the lower bulkhead head box section and also welded to the A pillers.
David.
D4VE
Member #: 10749
lowestoft suffolk
Brett... how will you weld this to original flat bit that its sitting on? Any more pics? As id like to something similar to another shell im doing
Nothing gets past Dave lol
Its already done mate ill see what pics I took when im on the laptop
Mowen123
Member #: 5593
Taunton, South West
Sorry I meant 2mm.
Right so a few different sizes.
I used 1.2mm steel on mine.
1mm will be fine, id be happy with .9 tbh
Sam
Member #: 1686
Oxford
You're looking at as an estimate
4kg for 2mm thick ally
6.7kg for 1.2 steel.
2.4kg for 1.2 ally
2kg for 1mm ally
OMG Robert that's a big one
Mowen123
Member #: 5593
Taunton, South West
Ah brill. Now I know what a few of you have used I feel a lot more confident.
