| Home > Help Needed / General Tech Chat > 8mm -10mm fuel pipes i/d or o/d | |||||||
8th Aug, 2005 at 07:50:05pm
Just gotta 2 gallon foam filled alloy fuel cell,and a pump.I know the return must be bigger than the flow but are peeps using 8mm i/d flow and 10mm i/d return Edited by Dangerous on 8th Aug, 2005.
8th Aug, 2005 at 08:17:59pm
I am going to use injection solid fuel lines, about 8.5mm O/D but quite thin walled.
8th Aug, 2005 at 08:27:36pm
On 08/08/2005 20:17:59 Tom Fenton said:
I am going to use injection solid fuel lines, about 8.5mm O/D but quite thin walled. Same sized feed and return, but with a restrictor in the feed line to the reg. The reg inlets/outlets are only 6mm,why not redrill the outlet to max approx 7-7.5 Metro used 8mm return 1/4" feed I believe?? true but thats 94 bhp
And if the pipe is will only flow as much as its restrictor,why 10mm i/d return when the reg is only 6mm i/d outlet
9th Aug, 2005 at 08:55:35am
If you need some hose ho about
9th Aug, 2005 at 08:59:02am
I use 10mm feed and 8mm return
9th Aug, 2005 at 11:20:45am
i'm using 8mm feed and return and havent had any fuelling issues yet. On 20th Oct, 2015 Tom Fenton said:
9th Aug, 2005 at 03:50:03pm
8mm feed and return. Never had a problem for the first 3/4000 odd miles. Then it all went pete-tong. Ended up with the restrictor.
Edited by turbodave16v on 9th Aug, 2005. On 17th Nov, 2014 Tom Fenton said:
9th Aug, 2005 at 03:52:42pm
I use 8mm feed& return on the racer and have no probs at all.
AlexF |
9th Aug, 2005 at 07:19:29pm
Its all very good putting I have 10 and I have 8,
9th Aug, 2005 at 07:31:51pm
i have 8 and 8 but its only done about a mile and a half lol
9th Aug, 2005 at 10:55:14pm
On 09/08/2005 19:19:29 Dangerous said:
Its all very good putting I have 10 and I have 8, But the question was i/d or o/d As a 8 mm o/d pipe is only around 6 on the i/d can we try again please edited mine to suit! Basically - easy way to tell if you've got a problem is to run whatever pipes you're going to run. Now set your fuel pressure to a low figure - say 2psi with the engine off. Finally, connect a pressure gauge tee-pieced into the return line as close to the regulator as possible. With the pump running, you should see a mere flicker on the gauge as the diaphram in the regulator lifts. You will probably see around 0.5 psi due to the 'head' of petrol making its way along the return line up from under your car to the top of your tank, but not much more. Certainly, if you're seeing even 1psi or more, then you've got one of the following: a) too restrictive a return line b) an excessivly high flow/pressure pump for the size of return line you're running c) must be another reason but can't think of one
Another thought about going so large on OD on the return line... There is NO point in running a pipe at any point between the regulator and tank return that has an ID greater than the ID of the pipe out of the bottom of the regulator. The restriction along any length of pipe is dependant on the smallest diameter anywhere - no matter how short the distance - along the length. Edited by turbodave16v on 9th Aug, 2005. On 17th Nov, 2014 Tom Fenton said:
9th Aug, 2005 at 11:07:28pm
other usefull reading...
9th Aug, 2005 at 11:17:03pm
