Home > For Sale > Few Bits for sale
Just sorting out some stuff I'll not be using. Pics to follow.
CAM 6232 crankshaft. Was in an MG Metro engine I bought ages ago for the block. In fairly good order with small marks on the tail, nothing serious. Mains all look good as do 3 of the big end journals. The fourth is badly worn. It will require a regrinds on the big ends at the least.
£30
Rear camber/tracking brackets. Think they are from Minispares.
£20
Rear beam made from cut down subframe. I've had a change of mind and gone for a flash ally beam. There's not any real rust issues. Had the hole saw on it and partially seam welded. Needs finishing off.
£30
Metro turbo exhaust manifold. Bit modified. Had the lugs ground off the top, the holes have been slotted and ported. Dividers have been back cut to allow the GT17 to be fitted. Was working well on my car for ages. Last time I had it off the car, I found it to have a hairline crack on the middle port. Could be welded up, but I had a spare to use instead.
£25
Offers welcome on all this stuff.
Can I have dibs on the crank based on pics of the taper?
Paul. The other side of the taper has a bit of a mark. I thought I had a pic, but it seems I didn't take one of that side.
Crank tail pics...
Thanks, Ill leave it
kim395
Member #: 10375
Hey are you going to mini in the park?:)
I'm not going to be able to make it now.
I could possibly arrange to pass it to someone local that is going?
kim395
Member #: 10375
Ok :) what's the lowest you'd take for the camber brackets?
