| Home > Help Needed / General Tech Chat > 12G206 | |||||||
![]() 321 Posts Member #: 557 Senior Member Ireland |
9th Aug, 2005 at 05:12:30pm
The 12G206 head is the same as the 12G295 head correct? And just as useful for a 998 turbo... |
9th Aug, 2005 at 05:36:15pm
If i remember corectly its the same except it has a bigger combustion chamber, so its better. On 28th Aug, 2011 Kean said:
9th Aug, 2005 at 05:45:48pm
yep i had one not long ago a supurb 998 head with all the right bits alreadey on it.
265 Posts Member #: 368 Senior Member Roseville, CA (USA) |
9th Aug, 2005 at 10:16:59pm
Sweet! I have one on my shelf, and had planned on using it on a 998 rebuild. Now I know why it's desirable.
10th Aug, 2005 at 08:37:38am
It's NOT got a bigger combustion chamber. The ONLY difference between a 206 and a 295 is the machining for the rings that go between the head and inlet. The steel ones. On 13th Jul, 2012 Ben H said:
10th Aug, 2005 at 09:59:53am
So which of the two would be more desirable from your point of view Vegard? |
10th Aug, 2005 at 11:51:47am
None. It doesn't make one blind bit of a difference. On 13th Jul, 2012 Ben H said:
450 Posts Member #: 449 Senior Member Oxford |
10th Aug, 2005 at 03:09:43pm
10th Aug, 2005 at 03:32:33pm
Id say that a 295 that has been ported and is without valves is no more valuable than a stock one. Have you tried getting OS valves for them... HORRIBLE!
11th Aug, 2005 at 03:22:18pm
