Home > 998cc > going from bpr 6 to bpr 5
Rammie2000
Member #: 10190
belgium
Hi. I ran the 998 of my stepsister to the imm with no problems what so ever exept 1... when it is running low revs ( idle and just above as for example waiting in a q) it makes the sparkplugs go dead. ( when normal running the sparkplugs are nice and brown when in q or long time idle they get so black that they stop sparking) a normal clean with a wire bruch always solves it. But now i was reading in the Haynes that a 998 should run on bpr 5 es instead of the bpr 6 es that are in there now. Would it make any difference?
No, not really, 6s are what I've always used with no problem.
i had issues wetting 7es, went down to 6es and never had problems too
what afr are they wetting at?
Chalkie
Member #: 9764
Northamptonshire.
My 998 ran alot better on 6's than it did 5's
Rammie2000
Member #: 10190
belgium
hmm. must be honest i do not know the afr all i know is that it is running 4.1 co on idle and 3.5 on revs whish is more or less within legal norms for a car of those years ( here in belgium)
D4VE
Member #: 10749
lowestoft suffolk
Is this purely for the 998s? I run 8s? Always spot on. 6's in my 998 n 1275 n/a
Edited by D4VE on 15th Aug, 2014.
Nothing gets past Dave lol
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
Glad emissions are not an issue in Queensland
engines shouldn't eat there own shit!
Rammie2000
Member #: 10190
belgium
Okey the shop only has the bosch equivalent. .. can't hurt trying right...
The co? Here the grade of co changes with the build year of the car. Or the sparkplugs? If i read correct the 850 ,998 and 1100 should run 5's and 1275 6's
Cables69
Member #: 10196
R's have a resistor E's don't, you can fit ford rs turbo plugs (don't know whether there 5 or 6 or 7's) they're a colder plug for boost or hi compression
Rammie2000
Member #: 10190
belgium
so the 5 thing did work ( it are bosch plugs). done some miles with it and no problems what so ever. color is good to.
