| Home > General Chat > Dismantling k1200RS to bare head | |||||||
![]() 218 Posts Member #: 9213 Senior Member Scotland |
18th Aug, 2014 at 12:51:12pm
Hi guys,
18th Aug, 2014 at 04:34:59pm
Sounds a bit steep to me, I would have that fastcarl would have done it cheaper.
18th Aug, 2014 at 07:38:22pm
The collets are tiny so careful you don't loose any like me!
25th Aug, 2014 at 12:38:17pm
£170 is very over priced, I would shop around |
211 Posts Member #: 10890 Senior Member Twin Cam Turbo Build In Progress Rothwell, Northants |
2nd Sep, 2014 at 11:06:11pm
Wheres fast carl based and how can I get hold of him? |
3rd Sep, 2014 at 06:03:50am
red and white banner top of page 'Force Racing' and is leeds based Yes i moved to the darkside |
3rd Sep, 2014 at 08:29:32am
just about to get round to doing this. What temperature do they heat the head to when doing the welding? Is there any issue with keeping the valves etc assembled in the head during the process or is this a no no? Only real issue i can think of is excessive heat or perhaps preventing a good clean down of debris after skimming etc
3rd Sep, 2014 at 02:48:13pm
Depending on how much has to come off you really need to take the valves out as the are very close the head face as it is. Have a look for yourself, use a steel rule and place it on edge across the chamber across the valves ande see how close the valves are On 26th Oct, 2004 TurboDave16v said:
11th Sep, 2014 at 12:24:27pm
that's the head and block all stripped down apart from valves. Never done any head work before, so will need to go out and buy a valve spring compressor. Are they universal and all capable of removing bike valve springs or do i need something special? Any recommendations would be much appreciated!
11th Sep, 2014 at 02:54:30pm
Where are you sending it to get the work done?
6th Oct, 2014 at 01:29:10pm
Minor update. Got round to taking out the valves using a g clamp and cut out bit of brass. Worked a treat! Using a magnet to grab the collets equally so! NOt sure how easy refitting is going to be however...
6th Oct, 2014 at 04:46:29pm
Yeh you will need to remove them for welding. I replaced them as they were a pig to get off without damaging them. I was a bit shocked how much they cost (£40 a set i think) so kind of wished id been more careful. I think if you made up the right tool you could get them off and try and reuse.
6th Oct, 2014 at 09:44:53pm
I've just ordered some of these |
