| Home > Help Needed / General Tech Chat > Which silicone bend do we need? | |||||||
9th Sep, 2014 at 08:53:30pm
Pipe size is 50mm, just mocked up the pipe route using a piece of intake flexi, but obviously I've never really ordered any silicone pipes so I'm not sure if they do a large radius bend? Picture attached so you can see what we need. Cheers.
![]() 330 Posts Member #: 9628 Senior Member |
9th Sep, 2014 at 09:01:25pm
Have a look on google,
![]() 324 Posts Member #: 9441 Senior Member South Devon |
9th Sep, 2014 at 09:04:55pm
Maybe a 15° from the turbo and a 90° into the plenum? |
9th Sep, 2014 at 09:35:13pm
Ash hose ebay Yes i moved to the darkside |
10th Sep, 2014 at 07:56:04am
I got all my stuff from this guy too
On 9th Sep, 2014 Brett said:
Ash hose ebay |
10th Sep, 2014 at 08:10:06am
You'll not get a silicone pipe to do what you want. You'd be better getting an alloy or stainless tube bent how you want it and putting a straight silicon joint at each end.
![]() 1043 Posts Member #: 10424 Post Whore Swansea boyo! |
10th Sep, 2014 at 10:04:12am
Looks like a massive gap to me! Two 45s and a straight bit? Or with a 90 in the middle? Hate hoses! They don't die, they just get faster! |
10th Sep, 2014 at 01:06:07pm
Take another pic without that flexible hose on. If something is worth doing, it's worth doing half of. |
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
10th Sep, 2014 at 03:34:36pm
Do what wil H says, or if you have access to a tig extend the plenum chamber so you can use a of the shelf hose! "Cars are a lifetime of pain" |
10th Sep, 2014 at 04:14:52pm
10th Sep, 2014 at 04:17:12pm
2 off 45's and a straight alloy piece to join, but it looks like you've a diameter change to deal with. Plus that plenum will probably cause issues with the boost hose blowing off.
10th Sep, 2014 at 04:28:32pm
The diameter is a couple of mm difference, the turbo is exactly 50 and the plenum is around 48, I don't think the pipe blowing off will be a problem as it's probably only going to see 8psi max, I could ask a mate to tig a new nubs on the end if it ever became a problem. I think you might be onto a winner with 2 45s and some pipe Tom as there should be a little give in the silicone and I can always shuffle the turbo angle a little. On 26th Jan, 2012 Tom Fenton said:
![]() 143 Posts Member #: 2764 Advanced Member Halesowen |
11th Sep, 2014 at 01:01:36pm
Carl, there is a good alloy welder in West Brom who I used for the Volvo intake. Reasonably priced as well if you want the plenum/turbo modifying to make it easier. I'll be using him for mine! 1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats. |
11th Sep, 2014 at 02:23:07pm
What about snapping the throttle shut at 8psi... i think it will pop off i had mine the same and to cure it i filed 2 groves around the plenum inlet and ran 2 clamps it saw 2+bar after that
On 10th Sep, 2014 Carlzilla said:
The diameter is a couple of mm difference, the turbo is exactly 50 and the plenum is around 48, I don't think the pipe blowing off will be a problem as it's probably only going to see 8psi max, I could ask a mate to tig a new nubs on the end if it ever became a problem. I think you might be onto a winner with 2 45s and some pipe Tom as there should be a little give in the silicone and I can always shuffle the turbo angle a little. Yes i moved to the darkside |
11th Sep, 2014 at 04:35:17pm
When I had trouble with IC hoses blowing off at Avon (temporarily fixed with lots of cable ties) I just put three small self tappers in the plastic IC inlet pipe and tightened up the clamp on top of them-no more problems. |
11th Sep, 2014 at 04:53:04pm
I'm a div and I've got two 45s and some pipe sent to mine instead of Carls. Ian, I'll drop you a pm on Facebook, I don't really fancy blowing a HOSE! Edited by Shauna on 11th Sep, 2014. They don't die, they just get faster! |
11th Sep, 2014 at 06:16:16pm
On 11th Sep, 2014 Shauna said:
I don't really fancy blowing a hoe!
11th Sep, 2014 at 06:56:14pm
11th Sep, 2014 at 07:02:58pm
It's the crack on my phone screen!
On 11th Sep, 2014 Carlzilla said:
Typo queen! They don't die, they just get faster! |
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
11th Sep, 2014 at 07:07:45pm
Resisiting a crack joke here... On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
11th Sep, 2014 at 07:10:06pm
Well, I like hoes and dp, why not! They don't die, they just get faster! |
11th Sep, 2014 at 07:13:32pm
I think there's a little room left in my signature... On 11th Feb, 2015 robert said:
11th Sep, 2014 at 07:17:50pm
11th Sep, 2014 at 07:45:52pm
Well, I like hoes and dp, why not! I was hopping someone else would pickup on that lol, and top man
