Home > Help Needed / General Tech Chat > modded HIF 44 carb problem
rattydriver
Member #: 10808
leicester
I'm using a modded HIF 44 carb on my turbo build but I have a problem,
The car won't run with the float valve vent blocked, it only runs for a second or so then dies.
If I leave the vent open it will run all day.....
Ive just typed out a long reply to this then lost wifi :(
is it a converted na carb ?
In short
Search the t piece trick
sim_ou_nao
Member #: 114
Porto/Portugal
Have you drill a hole in here?
Pedro Silva
rattydriver
Member #: 10808
leicester
Done the 'T' piece mod and its running, will hopefully take it for a run tomorrow.... Don't know about the hole in the mounting flange
sim_ou_nao
Member #: 114
Porto/Portugal
You can also try drill a 3.2mm hole...
Pedro Silva
