Home > Help Needed / General Tech Chat > Gear selector rod bushings
Mike-998
Member #: 9774
Buckinghamshire
I was about to assemble my rod change gear selector but noticed the bushes that the main rod and the short rod the other side of the yoke run in were well worn, to the point where they were egg shaped, so I knocked them out.
After a bit of searching I found that rover never sold them as a replacement part, and none of the normal mini stockists made them or knew where to get them.
This is what the bush looks like, worth through to the steel backing:
And this is where it came from:
Does anyone have any suggestions? Or am I going to need to get some one off bushes made/buy a new housing.
What is the OD of the housing the bush fits in, and the OD of the rod that runs in it?
What you are after ideally is either a DX or DU series split bush, if you are lucky it may be a standard size that you can buy from a bearing supplier. Otherwise you would need to get a length of something like oilite and have a bush machined, it would be easier to make a top hat bush on a lathe than to attempt to copy the original thin wall shell bush.
Edited by Tom Fenton on 16th Sep, 2014.
Mike-998
Member #: 9774
Buckinghamshire
The bush OD is 15.15mm and the Rod OD is 12.60mm
Which looks like it translates to the 19/32 OD, 1/2 ID x 1/2 length bush on this page?
http://www.onlinebearings.co.uk/DX-Series-...h-Imperial.html
Edited by Mike-998 on 16th Sep, 2014.
There you go jobs a goodun. Should be no more than a couple of quid each.
PS
A DU series is designed to run without lubrication so is the better choice here.
Clean the bore of the casing then push the bush in with some loctite bearing fit.
BOOM what a great result.
Mike-998
Member #: 9774
Buckinghamshire
Thanks for the help, I've ordered 4x DU 1/2 x 19/32 x 1/2 bushes, 72p each. I'll update the thread with the result for future searches.
Excellent stuff. I'll be overhauling mine in the near future and this is great info.
Fantastic. This was next on my list of jobs.
1380rich
Member #: 9766
Warwickshire
Ordered :) I've needed to sort this out for years! Cheers
Avon 2010 class c 3rd
Aubrey_Boy
Member #: 9962
I did mine a few months ago when I was adapting the Mini remote to the Vaux gearbox. Well worth doing, I was amazed how much the 1/2" rod had worn as well.
I had to polish the 1/2" T45 tube I replaced the rods with as it was a tight fit in the new DU's, not sure which was the problem, probably the tube.
Mike-998
Member #: 9774
Buckinghamshire
Turned up today, they seem to be the right size and were pressed in no problem, everything fits and moves and feels much better to me, But I can't put it on the car to see if it has helped with the sloppy gear changes yet.
jonny f
Member #: 9894
Dorking
Do you have a link to the ones you ordered?
