Home > Technical Chat > Scatter Pattern cam for 7 port crossflow
alaskanow0
Member #: 8466
Mansfield
Hi
What's peoples thoughts on running a Scatter Pattern cam on a 7 port head. Any real adverse effects?
I've been recommended and bought a certain cam, unaware it was a Scatter.
I rang the well respected Engine builder / supplier to question why they sold me a cam developed for a 5 port engine. He reckons it showed more power than the none scatter when they tested it on a 7 Port and it will work perfectly. He claimed due to the shared exhaust port.
Now surely the exhaust fires 180degrees, so no benefit wot so ever.
I'm now, in 2 minds to get a refund.
Edited by alaskanow0 on 7th Oct, 2014.
dazibee
Member #: 1356
TRURO, CORNWALL
Scatter cams were developed to minimise port robbing on a five porter if i remember correct. Cant see it being helpful on a seven port
Do they have any evidence to back this claim up, back to back tests etc?
alaskanow0
Member #: 8466
Mansfield
Apparantly, I think their full of shit. He sounded busted when I questioned the exhaust been 360degress apart.
Just trying to sell a product. For £350 I'd expect better. I was recommended by the other top engine builder not to use their AGSP 300 deg scatter on a 7 Port.
Send it back. Scatter cams are to even AFR across the inlets. The exhausts are not scattered I don't think?
alaskanow0
Member #: 8466
Mansfield
Exactly my thoughts.
D4VE
Member #: 10749
lowestoft suffolk
Sorry if i sound dumb but what exactly is a scattercam? I have driven a mini with one n hell it was lively but whats the difference?
Nothing gets past Dave lol
agreed, why would you want two cylinders to perform worse than the other two by using a cam for a 5 port head with the charge robbing problem that the scatter cam was designed to reduce the effects of
my thoufgts exactley, it will work sure but will run like a bag of shite
With the scatter cam, the valve timing is different across cylinders to reduce the effects of charge robbing as a result of the significant inlet valve overlap. A normal cam has the same valve timing across all four cylinders.
Ummmm, if you study the yellow bible, Viz suggests that on the more advanced scatter cams the centre exhaust timing is different and hence changes the LSA to suit the siamese exhaust port.
Just saying and have no opinion either way.
alaskanow0
Member #: 8466
Mansfield
I will be sending it back tomorrow. I honestly didn't think it was a Scatter Pattern, it was only the SP on the timing instructions that gave it away.
The annoying thing is I even said to them. ' I can't use the MED one because it's s scatter pattern'
Edited by alaskanow0 on 6th Oct, 2014.
I was thinking the same Paul,
if they are testing it against a std pattern cam that has a shit LCA, and 2 of the scatter cam cylinders have a better LCA then it will test better...
still not right though...
alaskanow0
Member #: 8466
Mansfield
Any body had any experience with the 649+ ?
There's an element of snake oil about scatter pattern cams, but there is also some truth that in the right application they can produce marginally better power.
Fact is, the centre exhaust valves see a different pulse pattern to the outer cylinders due to the siamese exhaust port. It then follows that a different exhaust pattern cam may produce better results.
The whole concept of charge robbing reducing total power output is flawed anyway.
I see what you're saying paul. If the most advanced scatter cams do indeed have 'scatter' on the exhausts then there may be some benefit.
However, there is no point on the inlets. What you really need is a cam that is specifically designed for the 7-port. i.e scatter on the exhausts and equal inlets (this might work it might not, I have no evidence either way). Not a cam that exists anyway.
The fact that the seller has suggested that the cam worked well might well be shown in an RR graph/graphs, but you never really know what is being compared.
As is usually the case, choose a cam that will put the power band where you want it.
Also, never spend more than approx. £200 on a cam.
Kent will grind whatever you want from a billet for that sort of price as long as you use existing profiles. Timing can be whatever you want.
Well, that's what I did for my custom ground scatter cam about 4 years ago. May have gone up a bit since.
Earwax
Member #: 10368
Australia
while i don't have 'data' to show the the two centre cylinders make more or less power with a scatter/ different timing...do any of the ECU's on minis individualise timing/fuel to see what each cylinder wants?
Off topic, but there are two issues with injecting the 5 port: 1. The inner cylinders need 10-20% less fuel than the outers. 2. There is a very small window in the engine cycle to inject fuel to ensure that it gets into the outer cylinders.
Rover got around this with port injection on the MPi. A number of us on here use the Megasquirt ECUs to do the same thing. Other brand ECUs are available.
Earwax
Member #: 10368
Australia
thank you paul S, that is good info sorry to OP, carry on
