| Home > Help Needed / General Tech Chat > Crankcase venting | |||||||
31 Posts Member #: 330 Member Aberdeenshire |
12th Aug, 2005 at 02:53:49pm
Just wondered what the thoughts were on crankcase venting. I currently have two K&N type filter vents on the rocker cover and the flywheel housing. I am about to fit an oil catch tank which has a top vent outlet. Is it best to retain the local filter or would it be better to plumb it into the the inlet hosing just after the air filter. I know that crankcase vent gas tends to drop the octane rating of the inlet charge but would that be significant at boost pressures of 7psi or less. Any thoughts appreciated. |
12th Aug, 2005 at 05:41:54pm
my advice would be to plumb all breathers to the the oil catch tank!
12th Aug, 2005 at 07:53:40pm
i was running just the 2 breathers (transfer and timing covers) and was getting a fair old bit of smoke out of the transfer case one even with no bore/ring wear...since then i fitted a rocker cover with breather and i hardly get any smoke from them...no idea why though. On 20th Oct, 2015 Tom Fenton said:
22nd Aug, 2005 at 09:18:19am
Thanks lads. So you would advise against plumbing the catch tank vent into the inlet would you?
22nd Aug, 2005 at 09:27:23am
Yes, because oil fumes reduce the Octane of the fuel + that it soots down the engine. On 13th Jul, 2012 Ben H said:
22nd Aug, 2005 at 11:19:56am
Excellent. Thanks for the replies.
339 Posts Member #: 399 Senior Member Austria |
13th Jul, 2006 at 11:32:05am
I am distraught.
53 Posts Member #: 1013 Member OXFORD |
17th Jul, 2006 at 02:48:48pm
can a breather filter be fitted to the largish nipple on top of the inlet manifold. i see no use for it? |
17th Jul, 2006 at 06:00:48pm
Why would you want to fit a breather on the inlet manifold ? |
