Home > Help Needed / General Tech Chat > Removable steel front
Nick warwick
Member #: 8926
Sheffield
Have/how have you guys done a removable steel front?
Replacing my front end this winter but would really like the access a removable front gives without going fiberglass.
Nick
I'm going to hinge mine from the bulkhead using articulating boot hinges
D4VE
Member #: 10749
lowestoft suffolk
Weld wings n front panel together, mounted via pins in front bolt holes and couple bolts on the a panel under the seam, n have bonnet kn normal hinges or pins
Nothing gets past Dave lol
I want to make a metal removable front too. May tackle it next year. Was planing on just bolting it in place via the front of the subframe and A-panel brackets, much like the fibreglass frontend it's replacing.
evad1980
Member #: 10165
Stansted, Essex
Im doing the same with mine at the mo, have a look at my build thread. Albeit it is fibreglass but I guess you could do something similar with a steel front. Although mine will flip up eventually.. Pretty sure just removeable would be easier....?
Rammie2000
Member #: 10190
belgium
mini is hinged at the front but the hinge point is a bolt so can easy be removed. its connected to the a-panel and top of the bulchead with simple snap clos locks ( ill take a pick when phone is charged. its verry ridget.
Nick warwick
Member #: 8926
Sheffield
My idea is to do the same as what everyone does with putting a tab on the a panels and using that to bolt them together/release. I will be doing the same but reverse it so it cannot be seen and its inside the wheel arch rather than through the a panel and seen.
Do people find that steel fronts rattle?
I would go flip but not sure just yet unless its just as easy to do.
D4VE
Member #: 10749
lowestoft suffolk
Unless its hinged at back dont flip it, it just gets in the way! Mines one piece and so annoying! Im going to replace it with removeable front for big jobs but normal bonnet just for checks
