Home > Help Needed / General Tech Chat > ROD CHANGE INSIDE THE CAR ??
Richie
Member #: 628
ok i have seen that a few of you lads seem to put the rod change inside the car ? how do i modify the linkages and what do i need to do it, as it just makes so much sense to have it there rather than have scroll pins come out and leave ya stuck in 4th :( lol
can anyone inform me of the ways *wink*
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
People do this by modifying the linkage, get rid of the stabiliser bar, and then fit a universal joint to the gear selector operator bar.
You need to solid mount the engine or else you won't be able to get gears easily.
As a note, if you use new roll pins on the gear linkage when you refit it, you will never have a problem with them falling out!
Richie
Member #: 628
yeh i did, think it was the collet that was knacked lol i just thought this way was a much cleaner method :) where do i purchase the universal joint, i intend to solid mount the engine so that is not a problem...cheers tom
ps did you get the sony sortid ?
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
the uj's are around £40 each from demon tweeks, I used two of them on my gear linkage. You have to solid mount the engine when doing this, so not nice for a road car.
hippyinamini
Member #: 520
nr hull
i was planning on this mod for my clubby, its gonna be a trackday/weekend car so im not too bothered about comfort but solid mounting the engine worries me a bit. especialy with all the power and torque from a good turbo lump. dosnt it put a lot of stress on the bell housing with there being no rubber to take up any movement?
doh! why did i start messing with it!
ive got rubber covered UJ's on mine to keep the grit out, think they were about £40 too, and their sleeve fits the rod perfect.
mini300bhp
Member #: 653
Cambs
Where did you get yours from then, mine were 70 each from demon f**ksake. Mate of mine used socket set ujs, Gears were like sturing porrage
Its only a bit of metal. If it blows it blows!
http://www.putfile.com/mini300bhp
£40 was a guess to be honest, mine are RAF issue *wink*
minimark
Member #: 19
newcastle
ie..... nicked
Mine were military ones too, got them off the 'bay *wink*
