| Home > General Chat > MD 500 Kent cam | |||||||
![]() 147 Posts Member #: 10874 Advanced Member Grimsby |
5th Nov, 2014 at 12:04:31am
My spec currently
mine: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=570945 |
5th Nov, 2014 at 12:18:01am
The SPI cam that you're using is actually a standard 1275 profile and incidentally the same as the Metro Turbo cam, (but nothing special) and I recall that it doesn't really like more than 5000ish RPM on a NA SPI engine either.
Edited by PhilR on 5th Nov, 2014. |
5th Nov, 2014 at 07:52:12am
The MG cam will work nicely, and will help towards higher rpm. But running out of puff can be lots of things. Fuelling and ignition advance are worth looking at first.
5th Nov, 2014 at 10:17:02am
Standard spi head so 33mm inlet 29mm exhaust
On 5th Nov, 2014 wil_h said:
The MG cam will work nicely, and will help towards higher rpm. But running out of puff can be lots of things. Fuelling and ignition advance are worth looking at first. Then any restrictions in the inlet side, what spec head have you got? mine: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=570945 |
5th Nov, 2014 at 10:44:41am
Years ago I ran a boggo Metro 1275 in a Mini, the standard cam does make the engine very "breathless" higher up, a different cam will help a lot.
5th Nov, 2014 at 01:12:46pm
My kc500 ( we are onabout the n/a mg cam arnt we? )
Yes i moved to the darkside |
5th Nov, 2014 at 01:26:57pm
On 5th Nov, 2014 Brett said:
My kc500 ( we are onabout the n/a mg cam arnt we? ) That used to hit a wall bang on 6300rpm i could push though it with boost but it felt quicker to change gear below this rpm mine: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=570945 |
5th Nov, 2014 at 05:47:23pm
yeah if its new, i sold my 2000 mile old one for half that iirc Yes i moved to the darkside |
5th Nov, 2014 at 06:49:46pm
My secondhand MG Metro can lets the engine run to well over 7K if i let it (like last weekend) but it does have the benefit of Turbophil head and a Robert tune. |
5th Nov, 2014 at 08:17:07pm
yes its the way to go with the cam change, a modded head would compliment each other and you could run say 10psi boost with no intercooler on good octain fuel with 26 ccs in the chambers
5th Nov, 2014 at 10:49:32pm
that's my plan after xmas Benross. :) mine: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=570945 |
6th Nov, 2014 at 11:29:34pm
my experience with this is
