Home > Technical Chat > Metro T3 vs Maestro T3
All-agroA+
Member #: 10611
doing a 1275 turbo conversion in the next week or so and decided to check the turbo i have for shaft play. There is a little play in the bearings but the compressor blades don't touch the housings. ive never seen this turbo run so i don't know what the seals are like.
if i put this on and it is in deed shot, can i use a T3 from a Maestro turbo that i have, seems in better condition play wise.
i cant see any specs on A/Rs on the maestro unit but has a part number of TB0342.
im guessing that being off a 2.0 liter its going to be hitting boost at like 4000 4500 rpms?
any ideas?
does the maestro core fit in the mini housings?
All-agroA+
Member #: 10611
they look very similar, could i just swap the exhaust turbine housings over? or would i need to change the turbine too?
