| Home > Help Needed / General Tech Chat > Is my block scrap? | |||||||
93 Posts Member #: 9597 Advanced Member |
27th Nov, 2014 at 06:33:30pm
I'm rebuilding my engine and noticed that the block has a piece broken off on the oil filter head mount. Can I fill it with jb weld and tap the thread or is it new block time? Edited by thejefinabox on 27th Nov, 2014. |
27th Nov, 2014 at 06:40:59pm
Timecert(much stronger than a helicoil in this situation) and a little silicone to help it seal and itll be fine. IMHO, curious what others say. or tap the threads right down and put a stud in there. and again a little silicone to seal it. definitely wouldnt waste time with any 2-part chemical metal.
27th Nov, 2014 at 06:42:13pm
infact id certainly build up atleast the inside edge with weld so it seals. turbo 16v k-series 11.9@118.9 :)
27th Nov, 2014 at 06:44:27pm
I would clean every thing up so its oil free, put a ligtly oiled bolt in there, spadge some devcon steel putty in, an when its dry undo the bolt out and draw file it flush. make sure you plug that oil way though so no shit goies up it....
27th Nov, 2014 at 07:31:23pm
I think the best solution is as Joe says, a suitably large cutter in the mill and face that down till you get to a faced surface again. Then as said a spacer with gaskets both sides to bring it back out if required. Devcon is surprisingly good stuff but with pressurised oil trying to get behind it I'm not sure how well it would last here.
27th Nov, 2014 at 07:57:45pm
I think you will be fine with some metal putty stuff in there. |
27th Nov, 2014 at 08:01:32pm
That would be easy to machine, so NO, it is not scrap... On 17th Nov, 2014 Tom Fenton said:
27th Nov, 2014 at 08:14:42pm
Grand, cheers for that. Slight over reaction so I'll pop on down to a shop on Monday and get it milled back.
28 Posts Member #: 9094 Member near hull |
27th Nov, 2014 at 08:47:56pm
Devcon or belzona are great products if the prep work is done correctly, ive used it many a time at work (offshore) in refacing many different sizes of flanges and relining pipework of different pressures, temperatures and products running through it. |
5th Dec, 2014 at 10:12:18pm
Just an update. After everyone gave me good advice to get it milled, I decided to do the opposite and fill it with jb weld. Sorry. I oiled up a bolt , screwed it in and filled around it. Filed it back and it seems good and solid. I'll see how it holds up. |
6th Dec, 2014 at 01:26:20pm
Not everyone told you to get it milled! :) |
6th Dec, 2014 at 01:33:33pm
Very true lol, it seems have stuck very well so I'm hopeful of it being a good mend |
6th Dec, 2014 at 04:37:35pm
6th Dec, 2014 at 05:21:05pm
Cheers Joe, your method worked grand. I nearly bought some devcon that is on eBay for £20 a tub as it's out of date but I chickened out. If anyone else dares it does seem fairly bargainous |
6th Dec, 2014 at 05:23:49pm
good good.
6th Dec, 2014 at 10:13:41pm
as joe said
6th Dec, 2014 at 10:35:04pm
could of got it built up with weld then milled down?
7th Dec, 2014 at 12:47:32am
Weld probably not but braze yes, but then you'd need to fuck around wit the threaded hole probably.
