Home > Help Needed / General Tech Chat > Bolt question
Chalkie
Member #: 9764
Northamptonshire.
Brought the Cooper s brake set up
Couldn't find the bolts that bolt the Flange to the disc there counter sunk thats all I know anyone got any ideas what size they are please
thanks
I am sure they are 1/4 unf
Minispares should sell them chap
Rammie2000
Member #: 10190
belgium
do you really need them? i drove a set like that without them for 3 years never had a problem that i noticed. or did i just got lucky?
P3sk3tt
Member #: 10566
Edited by P3sk3tt on 1st Dec, 2014.
Chalkie
Member #: 9764
Northamptonshire.
Thanks no wonder I couldn't find em I was looking under braking
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
thought those bolts are just to hold the disc to the hub when the wheel is removed?
once the wheel is bolted on its all held together and not going anywhere? i thought? do check tho..
Chalkie
Member #: 9764
Northamptonshire.
Yeah effectively but they put bolts there for a reason so it will get bolts.
I personal think if it put there for a reason its needed, you wouldn't leave the bolts out the drums.
slater
Member #: 1291
Suffolk / Birmingham
I never use bolts in the drums!
jonny f
Member #: 9894
Dorking
Same here, not even got the holes for bolts in my alloy hubs.
