Home > Help Needed / General Tech Chat > Rear ARB/silencer area pics req
adcyork
Member #: 6807
York
I'm after a picture of either an MS or KAD anti roll bar with a centre exit tail pipe. All of the pictures I've found online are taken from the ends where the linkage is.
I'm trying to work out how high I'll be able to package my silencer with the underslung type bar.
Best I can do at the moment.
This is the Minispares road ARB, but I used poly mounts similar to the KAD ones and welded the threaded plate to the subframe. I positioned it as close to the rear brace and the bar sits probibly half its diameter lower than the rear brace. You can see it in the pic as the light coloured strip. you should have no problems with a centre exit exhaust as it sits low anyway, my side exit just about fits, I had to make it sit a little lower at the rear.
adcyork
Member #: 6807
York
Cheers for that Sprocket.
I'm not using an off the shelf silencing solution so it makes it a little bit tricky to gauge.
I need a square on picture of the rear end with a centre exit exhaust silencer fitted. Anyone?
adcyork
Member #: 6807
York
Also, can anyone comment on what the driver is for mounting the miglia style ARB in the boot?
Is it a package issue stemmed from exhaust clearance due to a higher silencer mounting attitude? Or is it that a bar of sufficient stiffness (and size) wouldn't fit in the available envelope and so boot mounting is the only feasible option?
