Home > Help Needed / General Tech Chat > 2 1/4" Exhaust
I've bought a load of 2 1/4" exhaust pipes, bends and silencer and about to start cutting and welding.
Anyone had any major issues?
tricky to get past the pot joint, i gave up and went with 2"
PhilR
Member #: 10034
Birmingham
2" tube gave me about 1" total clearance close to the inner driveshaft pot. I think 2 1/4" would have just fitted, but I have a late front subframe with the extra holes to mount the engine 1/2" further forward. Other than that It might be a bit of a squeeze around the gear change?
MIG, TIG, Stainless, 304, 316? Is this a side mount turbo?
Edited by PhilR on 17th Dec, 2014.
I did expect to make up a special oval section piece to pass the pot joint, but I can get a 80 Deg bend through the gap with plenty of clearance.
I think mine is a later subframe, in fact, I know it is as it came of a 93 car.
It's all stainless stuff which I am going to TIG. Side mount turbo.
I plan on making a link pipe to the same shape as a 2" pipe that I have laying about. Hopefully will get past the shifter without going too low.
i run that sort of size paul , not too bad a fit , but i do have the downtube sitting a bit lower than the tunnel face.
Nick king
Member #: 9646
Bristol England
It's a tight fit but I managed around the pot joint, although I lost patience in the tunnel so put the gear linkage inside the car gives all the room needed.
Plenty clearance for 2 1/4" if you use hardy spicer joints, move the engine forward to the late model position and straighten out/ cut off the lip on the subframe at the back
Tupers
Member #: 9441
South Devon
Just out of interest why did you go for 2 1/4" over 2" and where did you get the bends?
I personally went for 2 1/4" because I have a sports cat, mid section and rear box silencers, so trying to offset the increased total system resistance, the cat being the biggest plug in the leak *oh well*
If you can reduce the pressure downstream of the turbo, then it will help with cylinder scavenging and VE. Basically free horsepower.
The bends came from ebay:
http://www.ebay.co.uk/itm/80-Degrees-Exhau...h-/261075849700
That fits nicely through the gap.
I can't comment on the 2 1/4" (as I used 2") but would highly recommend that company (Pipe Werx) as that's where I got my bits and their mandrel bends were very good quality.
They also do (or at least did back when I used them) a roller expanding service to make transition pieces and other strange things.
Well, it all fitted together OK. Just tacked at the moment but just enough clearance:
worth trying it with the gearlever in there before final welding paul?
JT
Member #: 637
Hertfordshire
I managed to fit 2.5" down pipe in mine. Although I will be running the gear linkage inside the car.
My build thread..
