Home > Wanted > High performance 998 pistons wanted
I might be after A+ ones, if they can take 10psi.
Could they??
Bore is not that important, but std is preferred as block is sound.
Still after such....
Mike-998
Member #: 9774
Buckinghamshire
Are you specifically after second hand ones? If not CalverST small bore pistons are said to be very good, I bought a set of +0.04s, £210 which I thought was good value. I think swiftune also do some small bore ones as well.
mw3
Member #: 9590
Derby
Russell engineering from Australia
Matt W
On 14th Mar, 2012 mw3 said:
Chalkie
Member #: 9764
Northamptonshire.
+1 But im sure this is where Calver gets his aswell
I'm after 2nd hand ones. On the cheap :)
