Home > Help Needed / General Tech Chat > duplex timing gears
minit3
Member #: 602
anyone had a problem were they catch on the casing thers a funny noise comin from dwn there now ive fitted them
You need to fit countersunk bolts where the back-plate fits to the end bearing cap, behind the crank chain gear.
wil
think you have to hammer a bit out on some covers to clear the chain...
as wil_ h states you have to replace the two hex head studs with counter sunk ones!
the ones which hold the timing cover backing plate to the engine they screw into the main bearing cap
dont run the engine any more untill you have investigated this further you may! have damaged the new drive gear.
in needs sorting NOW!
regarding bashing the cover out ????????????
never heard of this one on a mini A series engine
disregard this i can assure you !
Edited by BENROSS on 19th Aug, 2005.
Dr. jinG
Member #: 368
Roseville, CA (USA)
joeybaby83 is right. There is a dimple on the breather style chain cover that will hit and wear from the chain. It needs to be flattened a bit, with a duplex chain.
1967 Cooper 's' Turbo build @ www.drjing.com
nogin
Member #: 487
westbury, wiltshire
i second that as i had to do it
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
Gibbo
Member #: 34
Don't forget to check the end float, and also the bottom gear is correctly shimmed also.
Star Mag
Member #: 375
Leicestershire
yeah there is a half round piece os thin metal which i was advised to grind off< so i did dunno if i needed too, wouldnt hit it though as the timing cover is only thin.
right! the breather style cover.
let us know your findings
miniT3
giallofly
Member #: 164
The Stig..
Newport Pagnell
THE SOLUTION.........
Inside the breather type cover is a type of "shroud", it pionts towards the large pulley in the centre,it protrudes maybe 7/8mm. This can be drilled out by drilling out the spot welds but that often leads to making holes then oil leaks.
Personally i cut this shroud every centimetre or so then fold it back, so the edge closest to the timing gear is well out of harms way.
As far as the contersunk bolts go it is simple, your timing gear should have been supplied with these.These screw into to main bearing end cap at the very bottom, just 2 of them.
The countersink is a simple process of drilling with a 10mm bit deep enough so the allen screw bolt lays flush...
10 minutes work.(WHEN THE COVER IS OFF)
I did one just the other day on Alex B's and cousin Daisey's motor.
JF....*wink*
Edited by giallofly on 19th Aug, 2005.
and a top job of it he did too.
A Perfect description john!*happy*
Turbo Rich
Member #: 551
Ashington W.Sussex
On a related subject, as a result of the wider cover does anybody else's fan clip the breather outlet? Even after using 2 fan spacers my fan still clips the breather! Is it time for the club hammer??
Rich
it could be rich
i am sure minispares ,avonbar or the...
dreaded minsport do a slimmed down version of the breather outlet.
depends on how good you are with the club hammer...lol
This is a common problem.
I have always used the club hammer to good effect in this area.......
minit3
Member #: 602
yea i was suplied with the 2 bolts which i countersunk and fitted so im guessing its catching somwere else
Tom's got it.. Time to bring out the BFH.
Turbo Rich
Member #: 551
Ashington W.Sussex
I thought it maybe "hammer time".
Bit worried about ruining the olive green paint work on the breather though*wink*
giallofly
Member #: 164
The Stig..
Newport Pagnell
Yes, ou twat that bit or space your fan away from the "can" moving it closer to the rad making the fan more effective.
JF...*wink*
I just take a hacksaw down the outside of the 1/2" breather tube, and cut off the 'offending section'.
Remove and cast aside the rusty, oily mess of a flame trap and throw away. Source a stainless pan scrub from the wifes kitchen to replace it.
Before fitting, I weld two short pieces of welding rod in a X pattern over the hole between the can and cover to stop the pan scrub from falling out.
Now just cut a thin piece of steel to suit the shape of the breather can 'hole' and weld into place.
Bosh. Job done, no spacer, and no cowboy hammer.
ps - spacers make the rad difficult to remove if you have anything other than a skinny 998 rad AND inner wings...
