Home > General Chat > need help welding!
Ryancarlin1
Member #: 11056
South yorkshire
need some advice on welding this, ive got a welder but not very confident in myself to weld it, needs to be strong as its the rear subframe mounts! advice? or price for someone to come sort it? thanks
Edited by Ryancarlin1 on 31st Jan, 2015.
I would start by taking the oversill off and seeing how bad the rest is.
You can get a half floor with the outer sill etc attached. One of them and a heel board repair panel would sort that easily enough. Couple of days work to do it properly.
Might be best to put your location in your profile if you want somebody to come to you.
PhilR
Member #: 10034
Birmingham
I spy over-sills. You should cut more of the sill back to make sure there's not more rust waiting... you need to cut ALL the rust out, not just patch over the top.
Get practicing on scrap first until you build up confidence and learn how to test your practice welds for strength. Sills were the first weld job I did. It wasn't pretty, but it worked.
Use Waxoil after your done. You shouldn't have to be doing this if the last person had Waxoiled the current sills
Edited by PhilR on 31st Jan, 2015.
Ryancarlin1
Member #: 11056
South yorkshire
okay ill cut it back some more see what its like, im near sheffield, would like someone to come do it haha, i am wanting to learn to weld aswell though
Ryancarlin1
Member #: 11056
South yorkshire
Car looks close to the wall is it a cab?
I'm not far from Sheffield. Don't have much time at the moment, but if you are not in a rush then I could probably pop over at some point and go through the basics with you.
First things first though, brace the door opening up and get the rest of that oversill off. See what other horrors are lurking...
slater
Member #: 1291
Suffolk / Birmingham
Have a you got a half decent welder? If you start practicing on some scrap bits of steel it shouldn't take much the pick up mig welding. When welding thin stuff you have to use a bit of a 'pulse' kind of style instead of just holding the trigger in and going for it.
Ryancarlin1
Member #: 11056
South yorkshire
Na mate it's not a cab, it's about 2cm away from the wall haha, and I'm not really in any rush, I have a Clarke mig welder, just wanna no what to do for best!
wolfie29177
Member #: 476
The Black Countraaaaay
I learnt by going to a local fabricators and getting some of their scraps then taking them home and practicing. Trick is to make sure it sounds like a fry up cooking (I wrote down what settings I used on different thicknesses as well). Get a decent mask cos the ones that you get with the welders are fckin useless.
Masturbation is not a crime its a hobby
Where are you exactly? If you are not far away from me I can give you some pointers.
Ryancarlin1
Member #: 11056
South yorkshire
I live in treeton, Rotherham
Ryancarlin1
Member #: 11056
South yorkshire
fed up of it been like this now! haha, looked inside the sill and the rest looks okay! wanting a price for someone to come and weld it back together please!
I've too much on to offer to do it. I will come and give you advice on what to do if you want, PM me.
I would say it needs a heelboard repair panel then a repair to the sill as a minimum. But if that side is as the picture, what's the other side like?
Ryancarlin1
Member #: 11056
South yorkshire
the other sides sound mate as we took the door sil off and replaced that, under that is solid, but gonna have a second look when this side is done and its tipped the other way, would be good if you could come and have a look mate, it wont be till next month i will have the money to pay someone to do it, thanks
Ryancarlin1
Member #: 11056
South yorkshire
Tom Fenton, are you still busy mate? As I still Havnt sorted anything, need it doing at the end of this month!
